I’m running my Z-Wave network in Z-WAVE-JS-UI and I accidentally torpedoed my zwave stick. I thought I had backups made by the Advanced menu on the stick
Advanced Actions>General Actions>Backup>Export for the nodes.json
I tried to restore my stick using that file and nothing happened. What did I do wrong? Can I backup/restore a Z-Wave network/stick to protect myself from myself again in the future?
I spent the entire day reprogramming my entire Z-Wave network and now have to do the same for all my scripts and automation that aren’t working.
Thanks for the clarification. That said, I still have questions. Hope you don’t mind helping…
I had an NVM backup too. But it also did nothing. When I looked closer at the file, it was 0 bytes. I just made another backup of the new system using the NVM Management > Backup and Restore and it also was 0 bytes.
I now have the Backups setup for auto-backup, I don’t think I had that turned on before.
Do you happen to have an 800-series controller? Restores for 800-series aren’t supported in Z-Wave JS UI yet. Certain firmware versions produce 0-byte outputs. Newer versions can be backed up, but not restored yet.
