Hello i’ve got a problem with zwave integration
My system:
- zwave js ui (container promox) with zooz 800 key
- mqtt (container proxmox)
- HA (container proxmox) with mqq add-on
(I’ve also an raspberry 3b with zwave js ui and razpberry card (no problem with mqtt connexion)
In zwave js ui logs, i’ve:
DEBUG MQTT: Publishing to homeassistant/number/[TOTO]/config_number_10/config
but i’ve also:
2025-01-25 17:30:01.267 INFO MQTT: MQTT client offline
2025-01-25 17:30:01.267 INFO MQTT: MQTT client closed
2025-01-25 17:30:04.268 INFO MQTT: MQTT client reconnecting
2025-01-25 17:30:04.274 INFO MQTT: MQTT client connected
2025-01-25 17:30:07.285 INFO MQTT: MQTT client offline
2025-01-25 17:30:07.286 INFO MQTT: MQTT client closed
2025-01-25 17:30:10.286 INFO MQTT: MQTT client reconnecting
2025-01-25 17:30:10.290 INFO MQTT: MQTT client connected
2025-01-25 17:30:13.301 INFO MQTT: MQTT client offline
2025-01-25 17:30:13.301 INFO MQTT: MQTT client closed
2025-01-25 17:30:16.302 INFO MQTT: MQTT client reconnecting
2025-01-25 17:30:16.307 INFO MQTT: MQTT client connected
2025-01-25 17:30:19.321 INFO MQTT: MQTT client offline
2025-01-25 17:30:19.322 INFO MQTT: MQTT client closed
My conf:
