Zwave JS UI Error Z-Wave Server
I see this in the Zwave JS UI Add-on,
I think it does not look good but I’m not really having issues:
2024-02-26 19:44:42.164 ERROR Z-WAVE-SERVER: The node did not acknowledge the command (ZW0204)
ZWaveError: The node did not acknowledge the command (ZW0204)
    at Driver.sendMessage (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:5256:23)
    at Driver.sendCommandInternal (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:5454:28)
    at Driver.sendCommand (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:5565:15)
    at Proxy.set (/opt/node_modules/@zwave-js/cc/src/cc/MultilevelSwitchCC.ts:264:24)
    at Proxy.<anonymous> (/opt/node_modules/@zwave-js/cc/src/cc/MultilevelSwitchCC.ts:341:17)
    at ZWaveNode.setValue (/opt/node_modules/zwave-js/src/lib/node/Node.ts:1150:39)
    at NodeMessageHandler.handle (/opt/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:19:43)
    at Object.node (/opt/node_modules/@zwave-js/server/dist/lib/server.js:42:92)
    at Client.receiveMessage (/opt/node_modules/@zwave-js/server/dist/lib/server.js:125:99)
    at WebSocket.<anonymous> (/opt/node_modules/@zwave-js/server/dist/lib/server.js:57:45)
2024-02-26 19:44:42.181 ERROR Z-WAVE-SERVER: The node did not respond after 3 attempts, it is presumed dead (ZW0202)
ZWaveError: The node did not respond after 3 attempts, it is presumed dead (ZW0202)
2024-02-26 22:32:59.552 ERROR Z-WAVE-SERVER: Failed to send the command after 3 attempts. Transmission queue full (ZW0202)
ZWaveError: Failed to send the command after 3 attempts. Transmission queue full (ZW0202)
