I migrated maybe 60 zwave devices successfully from SmartThings using a technique I posted earlier, which was including my new zooz stick, then using silicon lab software to move the nodes to that hub, and then deleting ST hub. It worked great for all my GE devices. I cannot get the inovelli switches to be recognized. I see the node but I don’t know for sure which node is which device and they are listed as unknown. They ping. I tried to refresh the node and nothing. So I thought I would exclude and then include. But my zwave JS UI is stuck in waiting for inclusion/exclusion to complete as seen in this pic. I have restarted my home assistant multiple times. Same yellow hourglass. Thoughts?
Have you restarted the add-on? Maybe you can pull the zooz stick out and put it back in.
