I am starting up zwave via HA and again I run into trouble. Hope someone can help.
I do use zwave JS (is working, so zwave stick is present and OK) and I want to change to zwave js UI, because it should give the opportunity to edit zwave parameters (specially in a aeotec multisensor), what I do need sometimes.
I followed the instructions of
and also tried (happy to have backup!)
both with the same result: zwave js Ui is not starting up, both with the same log-entries. I cannot set any configurtion, because there is no configuration screen available.
The log shows:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Z-Wave JS UI
Fully configurable Z-Wave JS gateway and control panel
Add-on version: 1.6.2
You are running the latest version of this add-on.
System: Home Assistant OS 9.5 (amd64 / qemux86-64)
Home Assistant Core: 2023.2.3
Home Assistant Supervisor: 2023.01.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-zwave-js-ui: starting
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-nginx successfully started
s6-rc: info: service init-zwave-js-ui successfully started
s6-rc: info: service zwave-js-ui: starting
s6-rc: info: service zwave-js-ui successfully started
s6-rc: info: service discovery: starting
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
[19:20:03] INFO: Starting the Z-Wave JS UI...
./run: line 16: ./discovery: No such file or directory
2023-02-14 19:20:12.028 INFO APP: Version: 8.8.3
2023-02-14 19:20:12.038 INFO APP: Application path:/opt
______ __ __ _ _____ _ _ _____
|___ / \ \ / / | |/ ____| | | | |_ _|
/ /____\ \ /\ / /_ ___ _____ | | (___ | | | | | |
/ /______\ \/ \/ / _' \ \ / / _ \ _ | |\___ \ | | | | | |
/ /__ \ /\ / (_| |\ V / __/ | |__| |____) | | |__| |_| |_
/_____| \/ \/ \__,_| \_/ \___| \____/|_____/ \____/|_____|
2023-02-14 19:20:12.091 WARN STORE: scenes.json not found
2023-02-14 19:20:12.094 WARN STORE: nodes.json not found
2023-02-14 19:20:12.097 WARN STORE: users.json not found
2023-02-14 19:20:12.116 INFO APP: Listening on port 44920 host 0.0.0.0 protocol HTTP
[19:20:12] INFO: Starting NGinx...
2023-02-14 19:20:12.445 INFO MQTT: MQTT is disabled
2023-02-14 19:20:12.457 WARN BACKUP: Store backup is disabled
2023-02-14 19:20:12.458 WARN BACKUP: Nvm backup is disabled
2023-02-14 19:20:12.459 WARN Z-WAVE: Z-Wave driver not inited, no port configured
The configuration screen before first try to startup:
I am completely surprised.
After a coffee-break of some 20 minutes js UI appears to be started. In that time the MacBook laptop I have connected to HA (running on a seperate in10 server) ran out of power and had to be restarted.
Is it possible I had too little patience? Feel some kind of ashamed, but cannot help it: it’s what it is…
Anyway: I am one step forward.
But now I have other difficulties:
When re-starting the integration it asks for an url. default is ws://localhost:3000
But that does not work (cannot make connection)
I tried ws://a0d7b954-zwavejs2mqtt:3000
Same result
Tried ws://a0d7b954-zwavejsui:3000
Same result (but took some more time to tell)
I did find a0d7b954-zwavejs2mqtt in supervisor/addons/data
Hi, I have the same problem as @brinkgit on a new home assistant green. I have installed Z-wave Js UI and waited but nothing happens no button for WEBUI this is what the log looks like.
Add-on version: 3.0.2
System: Home Assistant OS 11.2 (aarch64 / green)
Home Assistant Core: 2023.12.1
Home Assistant Supervisor: 2023.12.0
[11:05:24] INFO: Starting the Z-Wave JS UI…
2023-12-24 11:05:31.736 INFO APP: Version: 9.3.2
2023-12-24 11:05:31.748 INFO APP: Application path:/opt
2023-12-24 11:05:31.815 WARN STORE: scenes.json not found
2023-12-24 11:05:31.838 WARN STORE: nodes.json not found
2023-12-24 11:05:31.844 WARN STORE: users.json not found
2023-12-24 11:05:31.888 INFO APP: Listening on port 44920 protocol HTTP
[11:05:32] INFO: Starting NGinx…
2023-12-24 11:05:32.212 INFO MQTT: MQTT is disabled
2023-12-24 11:05:32.228 WARN BACKUP: Store backup is disabled
2023-12-24 11:05:32.232 WARN BACKUP: Nvm backup is disabled
2023-12-24 11:05:32.238 WARN Z-WAVE: Z-Wave driver not inited, no port configured
2023-12-24 11:05:44.520 INFO APP: GET /health/zwave 301 19.638 ms - 191
2023-12-24 11:06:14.663 INFO APP: GET /health/zwave 301 5.993 ms - 191
2023-12-24 11:06:44.835 INFO APP: GET /health/zwave 301 3.900 ms - 191
2023-12-24 11:07:14.976 INFO APP: GET /health/zwave 301 2.589 ms - 191
2023-12-24 11:07:45.106 INFO APP: GET /health/zwave 301 3.868 ms - 191
