Zwave js ui keeps crashing Socket closed unexpectedly!
You cannot use both add-ons at the same time. If your integration is configured to use the core add-on, then you’ll need to switch. If it’s configured for Z-Wave JS UI, then you should uninstall the core add-on.
https://www.home-assistant.io/integrations/zwave_js/#can-i-switch-between-the-official-z-wave-js-add-on-and-the-z-wave-js-ui-add-on
Can I switch between the official Z-Wave JS add-on and the Z-Wave JS UI add-on?
You can, but you cannot run them both at the same time. Only one of them can be active at the same time.
Follow the instructions in the link above to switch, or follow:
