if you want LED on the Ezzee board to show ZWave_JS-UI Driver status: (Ready==>green, Not Ready==>Red) AND a GUI widget on your PI also showing the status:
Can be configured on as many Z-Net devices you want, just make sure to follow the procedure and specify the DEVICE_NAME accordingly in Node red and ZWAVW-JS-UI *****
1- Configure MQTT on Zwave-JS-UI to log the specific driver status in MQTT
- Open a browser and connect to you Z-NET Zwave-JS-UI interface #:8091
- Go in the configuratiuon tab (the cog wheel)
- Make sur that “Disable MQTT Gateway” is greyed
- Click on the MQTT Tab
- Enter a “Name” for your Z-NET gateway
- Fill in your MQTT Broker Ip adress in the “Hosts url”
- Enter your MQTT server port in “Port” # usually 1883
- In “Prefix” enter a unique name for this Z-net device #***** Please note for later use*****
- Make sure that you select “Retain” # switch turned in blue
- Enter your MQTT broker “Username” and “Password” if your MQTT server requires auth
- Click “SAVE” at the bottom right of the page
2- Configure Node-Red on Homne Assistant to log the status of the Z-Wave card in the specific Z-net
Connect to your HA server, find the device corresponding to your specific Z-net device Zwave card
Go in devices & services
Click on the Z-wave icon
Under the desired bridge, click on the devices
Find the device corresponding to the Zwave card in the Z-net (probably something that has ezzee in the model field) and click on it
find the device entity details by clicking on the status than on the cog wheel (ex:sensor.ezzee_status_3 in my case) # ***** note for later use ****
Start the Node Red Addon on HA
Copy the following:
[{“id”:“3f8ff68d90f074ad”,“type”:“tab”,“label”:“Flux 1”,“disabled”:false,“info”:“”,“env”:},{“id”:“e7f5aae55972280f”,“type”:“mqtt out”,“z”:“3f8ff68d90f074ad”,“name”:“”,“topic”:“”,“qos”:“”," r etain":“”,“respTopic”:“”,“contentType”:“”,“userProps”:“”,“co rrel”:“”,“expiry”:“”,“broker”:“1243ae281ae5c763”,“x”:870,“y” :440,“wires”:},{“id”:“4978253042667a79”,“type”:“server-state-changed”,“z”:“3f8ff68d90f074ad”,“name”:“”,“server”:“72efb04. 171835”,“version”:5,“outputs”:2,“exposeAsEntityConfig”:“”,“e ntityId”:“sensor.ezzee_status_3”,“entityIdType”:“exact”,“out putInitially”:false,“stateType”:“str”,“ifState”:“ready”,“ifS tateType”:“str”,“ifStateOperator”:“is”,“outputOnlyOnStateCha nge”:true,“for”:“0”,“forType”:“num”,“forUnits”:“minutes”,“i g norePrevStateNull”:false,“ignorePrevStateUnknown”:false,“ign orePrevStateUnavailable”:false,“ignoreCurrentStateUnknown”:f alse,“ignoreCurrentStateUnavailable”:false,“outputProperties “:[{“property”:“topic”,“propertyType”:“msg”,“value”:“DEVICE_ NAM E/HA/ezzee”,“valueType”:“str”},{“property”:“retain”,“propertyType “:“msg”,“value”:“true”,“valueType”:“bool”}],“x”:320,“y”:440,“wires”:[[“fa98a87c3c8f8e2b”],[“829cb3f05e5c4998”]]},{“id”:“fa98a87c3c8f8e2b”,“type”:“change”,“z”:“3f8ff68d90f 0 74ad”,“name”:””,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“true”,“tot”:“st r”}],“action”:””,“property”:“”,“from”:“”,“to”:“”,“reg”:false, “x” :640,“y”:420,“wires”:[[“e7f5aae55972280f”]]},{“id”:“829cb3f05e5c4998”,“type”:“change”,“z”:“3f8ff68d90f 0 74ad”,“name”:“”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“false”,“tot”:“s tr” }],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false, “x” :640,“y”:460,“wires”:[[“e7f5aae55972280f”]]},{“id”:“1243ae281ae5c763”,“type”:“mqtt-broker”,“name”:“MQTT server”,“broker”:“X.X.X.X”,“port”:“XXXX”,“clientid”:“”,“auto Connect”:true,“usetls”:false,“protocolVersion”:“4”,“keepaliv e”:“60”,“cleansession”:true,“autoUnsubscribe”:true,“birth Top ic”:“”,“birthQos”:“0”,“birthRetain”:“false”,“birthPayload” :" “,“birthMsg”:{},“closeTopic”:”“,“closeQos”:“0”,“closeRet ain” :“false”,“closePayload”:”“,“closeMsg”:{},“willTopic”:”“,” wil lQos":“0”,“willRetain”:“false”,“willPayload”:“”,“willMsg”:{} ,“userProps”:“”,“sessionExpiry”:“”},{“id”:“72efb04.171835 “,” type”:“server”,“name”:“Home Assistant”,“addon”:true,“rejectUnauthorizedCerts”:true,“ha_b oolean”:“”,“connectionDelay”:false,“cacheJson”:false,“heartb eat”:false,“heartbeatInterval”:“”,“deviceSelector”:“friendl y Name”,“entitySelector”:“friendlyName”,“statusSeparator”:“”," enableGlobalContextStore":false}]
- In Node-red, click on the hamburger menu uop right and select “import”
- In the pink window, paste the copied text above
- Click “Import”
- Adjust the flow for your specifics:
- Double click on the blue box (your HA device)
- in server make sure you select your HA server
- in Entity find and select the entity we noted few minutres ago
- in the outpout properties replace DEVICE_NAME with the name you gave above in the “Prefix” field of the MQTT, make sure you keep the /HA/ezzee after exemple: Z-NET-House/HA/ezzee
- Click finish
- Double click the pink mqtt box
- Either select your MQTT server if already configured in Node-Red OR select “Add a new MQTT-Broker”
- If you select “Add a new MQTT-Broker”
- Fill your MQTT broker info; IP, Port,
- Go in the security tab if your server use auth to COMPLETE user and password
- Click “add”
- Click Deploy
3- install python3
- Type and execute ‘sudo apt install python3’
4- Install paho-mqtt
- Type and execute ‘pip3 install paho-mqtt’
5- Create the python script that will check the mqtt topics and change LED and screen message accordingly
- Cut and paste the following in the file:
from datetime import datetime
from tkinter import * #for color status window
from tkinter import ttk
import time
import paho.mqtt.client as mqtt #for mqtt client
import sys
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)MQTT_BROKER=“192.168.40.70” replace with yout MQTT server ip adress
MQTT_PORT=1883 replace with yout MQTT broker IP port, usually 1883
MQTT_USER=“mqttgoldriver” replace with yout MQTT broker User
MQTT_PWD=“m20190107M” replace with yout MQTT broker Password
DEVICE_NAME=“cabanon” replace with the device name you have set in the prefix field of the ZWAVE-JS-UI MQTT TabEZZ_PIN_3=2 #ezzee pin 3 equals GPIO 2 on raspberry pi 3
EZZ_PIN_5=3 #ezzee pin 5 equals GPIO 3 on raspberry pi 3
EZZ_PIN_7=4 #ezzee pin 7 equals GPIO 4 on raspberry pi 3
GPIO.setup(EZZ_PIN_3,GPIO.OUT)
GPIO.setup(EZZ_PIN_5,GPIO.OUT)
GPIO.setup(EZZ_PIN_7,GPIO.OUT)ZWAVE_JS_UI_DRIVER_TOPIC=DEVICE_NAME + “/driver/status”
HA_CONNECTED_TOPIC=DEVICE_NAME + “/HA/ezzee”
first_run=“yes”#set status window environment
def donothing():
pass
#create ZNET status window
root = Tk()
#prevent status window being closed
root.protocol(‘WM_DELETE_WINDOW’,donothing)
#status window title
root.title(“Z-Net Status”)
#size of the status window
root.geometry(‘350x200’)
#enter status the window
root.eval(‘tk::PlaceWindow . center’)
#Configure a black background at start that can change to green,yellow and red
root.configure(background=‘black’)
#prevent user changing window size
root.resizable(False, False)
#define the zwave message label variable as tkinter StringVar
label_Zwave=StringVar()
#define the mqtt message label variable as tkinter StringVar
label_MQTT=StringVar()def on_connect(client, userdata, flags, rc, properties):
now = datetime.now()
date_time = now.strftime(“%Y/%m/%d %H-%M-%S”)
if rc == 0:
label=Label(root, textvariable=label_MQTT)
label.pack(pady=30)#create tkinter label space
temp_status=(“MQTT Connected “+date_time)#define tkinter message
label_MQTT.set(temp_status)#set tkinter label message
with open(”/etc/init.d/chkZNETLEDstate.txt”, “a+”) as file:
file.write(date_time+" MQTT Connected\n")
else:
label.pack(pady=30) #create tkinter label space
temp_status=(“MQTT NOT Connected “+date_time) #define tkinter message
label_MQTT.set(temp_status) #set tkinter label message
file.write(date_time+" MQTT Not Connected\n")def on_message_from_HA(client, userdata, message):
global HA_STATUS
global first_run
HA_STATUS=message.payload.decode()
if (first_run == ‘no’):
set_led()def on_message_from_Zwave_JS_UI(client, userdata, message):
global ZWAVE_JS_UI_STATUS
global first_run
first_run=‘no’
ZWAVE_JS_UI_STATUS=message.payload.decode()
set_led()def on_message(client, userdata, message):
print("Message Recieved from Others: "+message.payload.decode())def set_led():
global label
date_time = now.strftime(“%Y/%m/%d %H-%M-%S”)if (HA_STATUS != ‘true’ and ZWAVE_JS_UI_STATUS != ‘true’):
#3=0, 5=1, 7=1 RED
GPIO.output(EZZ_PIN_3,GPIO.LOW)
GPIO.output(EZZ_PIN_5,GPIO.HIGH)
GPIO.output(EZZ_PIN_7,GPIO.HIGH)
label=Label(root, textvariable=label_Zwave)
label.pack(pady=30)
label_Zwave.set(“ZWAVE_JS_UI Not connected to Zwave card”)
root.configure(background=‘red’)#change the status window to redif (HA_STATUS != ‘true’ and ZWAVE_JS_UI_STATUS == ‘true’):
#3=0, 5=0, 7=1 yellow
GPIO.output(EZZ_PIN_5,GPIO.LOW)
label.pack(pady=30)
label_Zwave.set(“HA NOT connected / Zwave-JS-UI connected”)
root.configure(background=‘yellow’)#change the status window to yellowif (HA_STATUS == ‘true’ and ZWAVE_JS_UI_STATUS == ‘true’):
#3=1, 5=0, 7=1 green
GPIO.output(EZZ_PIN_3,GPIO.HIGH)
label.pack(pady=30)
label_Zwave.set(“Everything is OK”)
root.configure(background=‘green’)#change the status window to greenclient = mqtt.Client(mqtt.CallbackAPIVersion.VERSION2)
client.on_connect=on_connect
client.on_message=on_message
client.username_pw_set(MQTT_USER, MQTT_PWD)
client.connect(MQTT_BROKER,MQTT_PORT)#subscribe to both topics
client.subscribe(HA_CONNECTED_TOPIC,qos=1)
client.subscribe(ZWAVE_JS_UI_DRIVER_TOPIC,qos=1)
client.message_callback_add(HA_CONNECTED_TOPIC, on_message_from_HA)
client.message_callback_add(ZWAVE_JS_UI_DRIVER_TOPIC, on_message_from_Zwave_JS_UI)#client.loop_forever()
client.loop_start()#Execute Tkinter
root.mainloop()
- Adjust the MQTT_BROKER, MQTT_PORT, MQTT_USER, MQTT_PWD and DEVICE_NAME to fit your specific environment
- Save and Close the editor ‘CTRL-X’ answer yes and then enter
6- Set the program to start at boot
- Type and execute ‘cd /home/pi/.config’
- Type and execute ‘sudo mkdir autostart’
- Type and execute ‘cd autostart’
- Type and execute ‘sudo nano showZNETstatus.desktop’
[Desktop Entry]
Encoding=UTF-8
Type=Application
Name=myprogram
Exec=python3 /home/pi/chkZNETstatus.py
Terminal=true
- Type and execute ‘chmod a+r showZNETstatus.desktop’
- Type and execute 'reboot’
