Zwave JS UI - Permanent MQTT errors
Hello ,
I have migrated from Zwave JS to ZwaveJS UI with the Zwave JS integration so Zwave JS UI is not used only as a control panel , so no mosquito Mqtt client has been setup
The zwave devices are working fine but there are the following permanent errors
2022-11-05 15:55:09.939 INFO MQTT: MQTT client closed
2022-11-05 15:55:12.939 INFO MQTT: MQTT client reconnecting
2022-11-05 15:55:13.676 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
Error: getaddrinfo ENOTFOUND core-mosquitto
at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:26)
2022-11-05 15:55:13.680 INFO MQTT: MQTT client closed
2022-11-05 15:55:16.680 INFO MQTT: MQTT client reconnecting
2022-11-05 15:55:16.685 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2022-11-05 15:55:16.689 INFO MQTT: MQTT client closed
Attached the zwave JS UI settings panel .
Please is it a known issue ?
Thank you
If you’re not using MQTT, then turn the Disable MQTT Gateway toggle on.
Thanks a lot @Tediore , enabling the mqtt gateway was the fix
I misunderstood the sentence " Enable the mqtt gateway to use Z-Wave JS UI only as Control Panel
It says “enable this” meaning the disable toggle itself, not the MQTT gateway. I can see how that’s potentially confusing though.
Hello, i’ve got the same problem. How to solve yours?
I use:
  • zwave js ui (proxmox container) with new key zooz 800
  • mqtt (proxmox container)
  • ha (proxmox container) with mqtt services.
thanks
