“UPGRADING THIS INSTALL HARSH”
“This copies your user files to the pi document folder deletes the zwavejs2mqtt folder and does a full blown reinstall and then copies your user files back and starts interviews from scratch after the reboot.”
“This reboots the server so it can run as a service vs doing a npm start that shuts down when you exit the terminal.”
“NOTE: If it does not reboot then it did not update ZwaveJS portion just rerun the upgrade to complete the upgrade sequence.”
cd
sudo apt update
sudo apt upgrade -y
sudo apt autoremove -y
killall node
mkdir /home/pi/Documents/store/
sudo cp -r /home/pi/zwave-js-ui/store/nodes.json /home/pi/Documents/store
sudo cp -r /home/pi/zwave-js-ui/store/settings.json /home/pi/Documents/store
sudo cp -r /home/pi/zwave-js-ui/store/users.json /home/pi/Documents/store
sudo cp -r /home/pi/zwave-js-ui/store/backups/ /home/pi/Documents/store
sudo rm -r zwave-js-ui
cd
mkdir zwave-js-ui
git clone https://github.com/zwave-js/zwave-js-ui
sudo cp -r /home/pi/Documents/store/ /home/pi/zwave-js-ui/
sudo chmod -R ugo+rw /home/pi/zwave-js-ui/
cd zwave-js-ui
npm install
npm run build ; sudo reboot
Outdated NodeJS error try this link
