I have 1 lastly added device (ID80) which worked fine for over 8 years in a Vera system. I excluded it from Vera, included in Zwave JS and get:
Now when I control the switches (dim or on/off) of the RGBW controller they quickly become unavailable and come back and at that time the entire Zwave JS integration is reloaded! All zwavejs devices become “unavailable” a moment. Since I have some toggle actions via node red and they are instantly triggered after controlling the RGBW switch/dimmer. I have tried to find what can cause this or how it happens but I am limited in my troubleshooting skills. I captured the following logs of me switching a button of the RGBW and then it reloads. I think after the reload the logging stops… What is causing this weird behavior?
2021-11-19T13:13:11.567Z DRIVER » [Node 080] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 16
└─[MultiChannelCCCommandEncapsulation]
│ source: 0
│ destination: 1
└─[MultilevelSwitchCCSet]
target value: 255
duration: default
2021-11-19T13:13:11.577Z DRIVER « [RES] [SendData]
was sent: true
2021-11-19T13:13:11.652Z DRIVER « [REQ] [SendData]
callback id: 16
transmit status: OK
2021-11-19T13:13:14.248Z DRIVER « [Node 080] [REQ] [ApplicationCommand]
│ source: 2
│ destination: 2
└─[MultilevelSwitchCCReport]
current value: 99
2021-11-19T13:13:14.301Z DRIVER « [Node 080] [REQ] [ApplicationCommand]
│ source: 3
│ destination: 3
current value: 99
2021-11-19T13:13:14.328Z DRIVER « [Node 080] [REQ] [ApplicationCommand]
│ source: 3
│ destination: 3
current value: 99
2021-11-19T13:13:14.389Z DRIVER « [Node 080] [REQ] [ApplicationCommand]
│ source: 4
│ destination: 4
current value: 99
2021-11-19T13:13:14.501Z DRIVER « [Node 080] [REQ] [ApplicationCommand]
│ source: 5
│ destination: 5
current value: 99
2021-11-19T13:13:14.545Z DRIVER « [Node 080] [REQ] [ApplicationCommand]
│ source: 5
│ destination: 5
current value: 99
2021-11-19T13:13:14.593Z DRIVER « [Node 080] [REQ] [ApplicationCommand]
└─[BasicCCReport]
current value: 99
I tried other setting for paramter 14 from below:
But that changes nothing
