Hello All,
So my Zooz Zen20 Powerstrip generates the same messages in my log over and over(3-4 times a minute or more) … I’ve disabled all of the power reading sensors, but continue to get log spam. Any ideas of how I should approach stopping this? I’ve tried excluding and doing a new inclusion, still the same issue. I’ve tried editing the config file and removing the COMMAND_CLASS_METER which drastically reduces the number of lines but obviously errors out at that point…
> 2019-10-17 20:12:55.989 Error, Node006, MultiChannelEncap with endpoint set to 0 - Send to Root Device
> 2019-10-17 20:12:55.989 Detail, Node006, Refreshed Value: old value=false, new value=false, type=bool
> 2019-10-17 20:12:55.989 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:55.989 Info, Node006, Received Meter report from node 6: Power=33.5W
> 2019-10-17 20:12:55.989 Detail, Node006, Refreshed Value: old value=33.6, new value=33.5, type=decimal
> 2019-10-17 20:12:55.989 Info, Node006, Previous value was 33.6W, received 30 seconds ago.
> 2019-10-17 20:12:55.989 Detail, Node006, Refreshed Value: old value=33.1, new value=33.6, type=decimal
> 2019-10-17 20:12:55.990 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:55.990 Detail, Node006, Refreshed Value: old value=30, new value=30, type=int
> 2019-10-17 20:12:55.990 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:55.992 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:55.993 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:55.994 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.089 Detail, Node006, Received: 0x01, 0x15, 0x00, 0x04, 0x00, 0x06, 0x0f, 0x60, 0x0d, 0x01, 0x00, 0x32, 0x02, 0x21, 0x32, 0x00, 0xe7, 0x00, 0x1e, 0x00, 0xe7, 0x00, 0xb6
> 2019-10-17 20:12:56.089 Info, Node006, Received a MultiChannelEncap from node 6, endpoint 1 for Command Class COMMAND_CLASS_METER
> 2019-10-17 20:12:56.089 Detail, Node006, Refreshed Value: old value=false, new value=false, type=bool
> 2019-10-17 20:12:56.089 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:56.089 Info, Node006, Received Meter report from node 6: Power=23.1W
> 2019-10-17 20:12:56.089 Detail, Node006, Refreshed Value: old value=23.1, new value=23.1, type=decimal
> 2019-10-17 20:12:56.089 Info, Node006, Previous value was 23.1W, received 30 seconds ago.
> 2019-10-17 20:12:56.089 Detail, Node006, Refreshed Value: old value=22.7, new value=23.1, type=decimal
> 2019-10-17 20:12:56.090 Detail, Node006, Refreshed Value: old value=30, new value=30, type=int
> 2019-10-17 20:12:56.090 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:56.090 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.091 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.093 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.094 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.189 Detail, Node006, Received: 0x01, 0x15, 0x00, 0x04, 0x00, 0x06, 0x0f, 0x60, 0x0d, 0x02, 0x00, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0xb5
> 2019-10-17 20:12:56.189 Info, Node006, Received a MultiChannelEncap from node 6, endpoint 2 for Command Class COMMAND_CLASS_METER
> 2019-10-17 20:12:56.189 Detail, Node006, Refreshed Value: old value=false, new value=false, type=bool
> 2019-10-17 20:12:56.189 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:56.189 Info, Node006, Received Meter report from node 6: Power=0.0W
> 2019-10-17 20:12:56.189 Detail, Node006, Refreshed Value: old value=0.0, new value=0.0, type=decimal
> 2019-10-17 20:12:56.189 Info, Node006, Previous value was 0.0W, received 30 seconds ago.
> 2019-10-17 20:12:56.190 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:56.190 Detail, Node006, Refreshed Value: old value=30, new value=30, type=int
> 2019-10-17 20:12:56.190 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.191 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.193 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.194 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.290 Detail, Node006, Received: 0x01, 0x15, 0x00, 0x04, 0x00, 0x06, 0x0f, 0x60, 0x0d, 0x03, 0x00, 0x32, 0x02, 0x21, 0x32, 0x00, 0x68, 0x00, 0x1e, 0x00, 0x69, 0x00, 0xb5
> 2019-10-17 20:12:56.290 Info, Node006, Received a MultiChannelEncap from node 6, endpoint 3 for Command Class COMMAND_CLASS_METER
> 2019-10-17 20:12:56.290 Detail, Node006, Refreshed Value: old value=false, new value=false, type=bool
> 2019-10-17 20:12:56.290 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:56.290 Info, Node006, Received Meter report from node 6: Power=10.4W
> 2019-10-17 20:12:56.290 Detail, Node006, Refreshed Value: old value=10.5, new value=10.4, type=decimal
> 2019-10-17 20:12:56.290 Info, Node006, Previous value was 10.5W, received 30 seconds ago.
> 2019-10-17 20:12:56.291 Detail, Node006, Refreshed Value: old value=10.4, new value=10.5, type=decimal
> 2019-10-17 20:12:56.291 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:56.291 Detail, Node006, Refreshed Value: old value=30, new value=30, type=int
> 2019-10-17 20:12:56.291 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.292 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.294 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.295 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.389 Detail, Node006, Received: 0x01, 0x15, 0x00, 0x04, 0x00, 0x06, 0x0f, 0x60, 0x0d, 0x04, 0x00, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0xb3
> 2019-10-17 20:12:56.389 Info, Node006, Received a MultiChannelEncap from node 6, endpoint 4 for Command Class COMMAND_CLASS_METER
> 2019-10-17 20:12:56.389 Detail, Node006, Refreshed Value: old value=false, new value=false, type=bool
> 2019-10-17 20:12:56.389 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:56.389 Info, Node006, Received Meter report from node 6: Power=0.0W
> 2019-10-17 20:12:56.389 Detail, Node006, Refreshed Value: old value=0.0, new value=0.0, type=decimal
> 2019-10-17 20:12:56.389 Info, Node006, Previous value was 0.0W, received 30 seconds ago.
> 2019-10-17 20:12:56.390 Detail, Node006, Refreshed Value: old value=0.0, new value=0.0, type=decimal
> 2019-10-17 20:12:56.390 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:56.390 Detail, Node006, Refreshed Value: old value=30, new value=30, type=int
> 2019-10-17 20:12:56.390 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.391 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.392 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.394 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.489 Detail, Node006, Received: 0x01, 0x15, 0x00, 0x04, 0x00, 0x06, 0x0f, 0x60, 0x0d, 0x05, 0x00, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0xb2
> 2019-10-17 20:12:56.489 Info, Node006, Received a MultiChannelEncap from node 6, endpoint 5 for Command Class COMMAND_CLASS_METER
> 2019-10-17 20:12:56.489 Detail, Node006, Refreshed Value: old value=false, new value=false, type=bool
> 2019-10-17 20:12:56.489 Detail, Node006, Changes to this value are not verified
> 2019-10-17 20:12:56.489 Info, Node006, Received Meter report from node 6: Power=0.0W
> 2019-10-17 20:12:56.489 Detail, Node006, Refreshed Value: old value=0.0, new value=0.0, type=decimal
> 2019-10-17 20:12:56.489 Info, Node006, Previous value was 0.0W, received 30 seconds ago.
> 2019-10-17 20:12:56.489 Detail, Node006, Refreshed Value: old value=30, new value=30, type=int
> 2019-10-17 20:12:56.490 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.491 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.492 Detail, Node006, Notification: ValueChanged
> 2019-10-17 20:12:56.493 Detail, Node006, Notification: ValueChanged
Any help would be greatly appreciated!
