Zwave module Yale locks- aren’t showing in home assistant but can’t exit network from touch screen
Hello all,
Hoping someone here can help me figure out the subject issue. This is happening with all 5 locks in the house. They are all some type of the version 1 Yale assure (model yrd226).
The only option I have in menu setting 7 of the lock is to exit the network but the locks aren’t showing in home assistant and wave exclusion does nothing.
A factory reset of the locks also did nothing. It let me re set the master code and rehand the lock but still the only option I have in menu setting 7 on the touch screen of the lock is to “exit the network”
Thank you all for any ideas or guidance.
For anyone that runs into this. The fix for me was uninstalling the lock and taking it to a foot away from my hub and doing zwave exclude. This would not work from 20 feet away. There is one other report of this solution on the web and I took a shot at it and it worked for me also.
