I have been slowly adding to my setup and recently acquired a Remotec ZFM-80 that I am trying to use as a momentary switch to activate my garage door opener via the relay terminals. This is my first zwave device but I have it setup on the HAAS screen and can turn it on & off.
How can I create a scene or timer to make it momentary? I need it to turn on for a second or 2 maybe then turn off automatically.
I do have the control panel installed and working but did not see anything that really helped me and have not found any good documentation on using the scene option in there.
I use a delay in one of my theater scenes that puts the lights at 100%, then after a 2:00 minute runs a dimmed version of the same scene in a slow transition (nice fade down effect!). I would think you could use the delay the same way.
I was using this relay to do the exact same thing. Let me find the config I had running. Side note though, the ZFM-80 kept going to a presumed dead state on my zwave network. I believe it was a range issue, it was only about 20 ft and 2 walls away from my zstick gen 5. I ended up returning it to Amazon.
Well… this is embarrassing. Turns out my Genie SilentMax1000 needs something a little fancier than a short to the terminals to trigger the door. I never even contemplated that it used something other than a simple open/close switch.
