I have some issues regarding multichannel group association with two fibaro smart implants.
currently running ha core in docker with zwave addon (1.4)
what i try to accomplish is to use group association between two smart implants,
si1 input -> si2 output, this should be done by adding si2 to group 2 on si1 but its not working at all.
After much here and there with fibaro support it might seem that the problem is the endpoint (target) for the group command.
according to fibaro the endpoint (target should be 5 for group 2 and 6 for group 3)
when i examine the zwcfg i find this:
<CommandClass id="142" name="COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION" version="1" request_flags="5" innif="true">
<Instance index="1" endpoint="1" />
<Instance index="2" endpoint="2" />
<Instance index="3" endpoint="3" />
<Instance index="4" endpoint="4" />
<Instance index="5" endpoint="5" />
<Instance index="6" endpoint="6" />
<Instance index="7" endpoint="7" />
<Associations num_groups="3">
<Group index="1" max_associations="1" label="Lifeline" auto="true" multiInstance="true">
<Node id="1" />
</Group>
<Group index="2" max_associations="5" label="Input IN1" auto="false" multiInstance="true">
<Node id="10" />
</Group>
<Group index="3" max_associations="5" label="Input IN2" auto="false" multiInstance="true" />
</Associations>
it seems to me that index is set to 2 with the correspondig endpoint of 2. this is probably the fault and i need to change the endpoint (target) for group 2 to 5. how can this be done?
