Zwave network doesnt work anymore after update
I have updated yesterday the zwave JS to the latest version. Since this morning I have strange behaviors in zwave communication. Some devices are reporting data (temperature etc),
but most of them don’t work anymore. here I try to switch on a light:
Any other people have problems with zwave?
Driver Version:
11.13.1
Server Version:
1.31.0
After that update I had only one failure. A double switch with temperature sensor (Qubino Flush 2) stopped reporting temperature. The entities were nonexistent.
I did reinteview about 10 times, won’t change. Factory reset, won’t change. Server restart, won’t change. Downgrade Zwave, won’t change. Update it again, won’t change.
I was already preparing to write up a issue on Git.
After all, tried reinterview even more times and suddenly the temperature sensor came back.
Very strange indeed, but it works again.
So yes, you are not alone, but there is hope :wink:
I moved back the an older backup and everything was working directly fine again.
Same happened to me aswell. Did multiple restarts and nothing seemed to fix it.
When I changed the logs from info to debug and restarted the addon it fixed itself and now everything is working.
Weird…
