both with and without quotes. I’ve also tried commenting out the “config_path” from the config and keeping the network key value in there. Is this right? The network key I’m using is the same in the un-commented options.xml under that config directory.
I’m asking here because there isn’t an example on the hass.io website of how to use this value.
Thanks for the reply, but I’m already using the options.xml file, and linking to the /config directory. That seems to be working fine.
On the Z-Wave page, it states that you can use a property called “network_key” in your configuration.yaml file instead. I’d like to go this route in case for some reason that directory gets removed or updated.
I was taking another look at the doc again to reference the portion I was talking about, and it looks like I was looking at an outdated version for some reason.
network_key (Optional): The 16 byte network key in the form “0x01,0x02…” used in order to connect securely to compatible devices.
So it looks as if I need to surround the key with quotes, and have no spaces. I’ll give this a go later tonight then.
Obviously, change the key to something random (i.e. replace each pair of 11 with other more random pair). Just ensure to keep the exact same format, including the quotes.
The one-liner from the Zwave configuration page is an easy way to generate a unique value for the network key cat /dev/urandom | tr -dc '0-9A-F' | fold -w 32 | head -n 1 | sed -e 's/\(..\)/0x\1, /g' -e 's/, $//'
I’m trying to setup my aeotec z-stick gen5 and am having trouble with the network_key option.
If I leave the network_key off, it works, but then I can’t use all of my devices fully. However, with network_key defined as 16 comma-separated hex values in quotes, it tells me the zwave component could not be configured.
Any ideas on what may be going wrong? I have these settings in configuration.yaml. Should they be somewhere else?
The problem actually ended up being something else. At some point, the path changed from /dev/ttyACM0 to /dev/ttyACM1 and that was causing the problem.
looks like now you can specify /zwaveusbstick instead of /dev/ttyACM0 and it figures out the usb enumeration automatically. Can anyone confirm? I’ve struggled with this also.
Just for anyone trying to hunt down the HASSIO auto generated network key, I finally figured out where it was stored. In the following file has the Z-wave network key config: “config/.storage/core.config_entries”. I guess when I set up HASSIO I put a key in (and didn’t remember) or it was auto generated but wasn’t in my other config files. I couldn’t figure out where to find it or pull it from the logs. After much hunting i figure it out and thought I would share.
