It has been very solid since a year or more, today, not sure if after a restart or when, is totally off.
Below the LOG, what can that be?
2019-08-24 18:19:56.765 Always, OpenZwave Version 1.4.3440 Starting Up
2019-08-24 18:22:04.073 Info, Setting Up Provided Network Key for Secure Communications
2019-08-24 18:22:04.073 Warning, Failed - Network Key Not Set
2019-08-24 18:22:04.074 Info, mgr, Added driver for controller /dev/ttyACM0
2019-08-24 18:22:04.074 Info, Opening controller /dev/ttyACM0
2019-08-24 18:22:04.074 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2019-08-24 18:22:04.074 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2019-08-24 18:22:04.074 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-08-24 18:22:04.074 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-08-24 18:22:04.074 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-08-24 18:22:04.074 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-08-24 18:22:04.074 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-08-24 18:22:04.074 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-08-24 18:22:05.075 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-08-24 18:22:05.075 Detail, contrlr, Removing current message
2019-08-24 18:22:05.075 Detail, contrlr, Notification: Notification - TimeOut
2019-08-24 18:22:05.078 Detail,
2019-08-24 18:22:05.078 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-08-24 18:22:06.078 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-08-24 18:22:06.078 Detail, contrlr, Removing current message
2019-08-24 18:22:06.078 Detail, contrlr, Notification: Notification - TimeOut
2019-08-24 18:22:06.079 Detail,
2019-08-24 18:22:06.079 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-08-24 18:22:07.079 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-08-24 18:22:07.079 Detail, contrlr, Removing current message
2019-08-24 18:22:07.079 Detail, contrlr, Notification: Notification - TimeOut
2019-08-24 18:22:07.089 Detail,
2019-08-24 18:22:07.089 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-08-24 18:22:08.091 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-08-24 18:22:08.091 Detail, contrlr, Removing current message
2019-08-24 18:22:08.091 Detail, contrlr, Notification: Notification - TimeOut
2019-08-24 18:22:08.141 Detail,
2019-08-24 18:22:08.141 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-08-24 18:22:09.141 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-08-24 18:22:09.141 Detail, contrlr, Removing current message
2019-08-24 18:22:09.141 Detail, contrlr, Notification: Notification - TimeOut
