I had an issues where my door lock wasn’t working, so I stopped my Zwave network. Now I can’t get it started again. Here is my OZW log.
I’m running Virtualbox on a Windows 10 host, and my guest is Unbuntu 18.04. I’ve exposed my USB Z-wave dongle.
2019-12-02 16:53:25.157 Always, OpenZwave Version 1.4.3440 Starting Up
2019-12-02 16:54:08.993 Info, Setting Up Provided Network Key for Secure Communications
2019-12-02 16:54:08.993 Info, mgr, Added driver for controller /dev/ttyACM0
2019-12-02 16:54:09.003 Info, Opening controller /dev/ttyACM0
2019-12-02 16:54:09.003 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2019-12-02 16:54:09.007 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2019-12-02 16:54:09.008 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-12-02 16:54:09.008 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-12-02 16:54:09.008 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-12-02 16:54:09.008 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-12-02 16:54:09.008 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-12-02 16:54:09.008 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-12-02 16:54:10.008 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-02 16:54:10.008 Detail, contrlr, Removing current message
2019-12-02 16:54:10.008 Detail, contrlr, Notification: Notification - TimeOut
2019-12-02 16:54:10.019 Detail,
2019-12-02 16:54:10.019 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-12-02 16:54:11.019 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-02 16:54:11.019 Detail, contrlr, Removing current message
2019-12-02 16:54:11.019 Detail, contrlr, Notification: Notification - TimeOut
2019-12-02 16:54:11.025 Detail,
2019-12-02 16:54:11.025 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-12-02 16:54:12.027 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-02 16:54:12.027 Detail, contrlr, Removing current message
2019-12-02 16:54:12.027 Detail, contrlr, Notification: Notification - TimeOut
2019-12-02 16:54:12.048 Detail,
2019-12-02 16:54:12.048 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-12-02 16:54:13.048 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-02 16:54:13.048 Detail, contrlr, Removing current message
2019-12-02 16:54:13.048 Detail, contrlr, Notification: Notification - TimeOut
2019-12-02 16:54:13.089 Detail,
2019-12-02 16:54:13.089 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-12-02 16:54:14.089 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-02 16:54:14.089 Detail, contrlr, Removing current message
2019-12-02 16:54:14.089 Detail, contrlr, Notification: Notification - TimeOut
