Hi all. First of all I want to say I am excited to join this community, this is my first post here and I look forward to learning more about home automation!
I have painstakingly added an Enbrighten In-Wall Smart Dimmer to my ZWave network. (I think). Here are the logs that display after adding the dimmer:
2021-01-20 19:49:31.377468824 [20210120 19:49:31.377 UTC] [ozw.mqtt.commands] [info]: Processed Message for "addnode" : "{\"secure\": false}"
2021-01-20 19:49:46.964576383 [20210120 19:49:46.964 UTC] [ozw.mqtt.publisher] [debug]: "Wed Jan 20 19:49:46 2021 PingResponse\n"
2021-01-20 19:49:59.090411614 [20210120 19:49:59.089 UTC] [ozw.library] [debug]: Detail - Node: 0 Received: 0x01, 0x07, 0x00, 0x4a, 0x0b, 0x02, 0x00, 0x00, 0xbb
2021-01-20 19:49:59.090792553 [20210120 19:49:59.090 UTC] [ozw.library] [info]: Info - Node: 0 FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2021-01-20 19:49:59.092274105 [20210120 19:49:59.091 UTC] [ozw.library] [info]: Info - Node: 0 ADD_NODE_STATUS_NODE_FOUND
2021-01-20 19:49:59.092303419 [20210120 19:49:59.091 UTC] [ozw.library] [debug]: Detail - Node: 0 Notification: AddDevice ControllerCommand - InProgress
2021-01-20 19:49:59.093213017 [20210120 19:49:59.092 UTC] [ozw.notifications] [debug]: Notification pvt_controllerCommand 1 6 0 Thread: 0xb3c5f010
2021-01-20 19:49:59.093686158 [20210120 19:49:59.093 UTC] [ozw.mqtt.publisher] [debug]: Publishing Event controllerCommand 0 NotificationTypes::Ctrl_Cmd_AddNode NotificationTypes::Ctrl_State_InProgress NotificationTypes::Ctrl_Error_None
2021-01-20 19:49:59.247979186 [20210120 19:49:59.247 UTC] [ozw.library] [debug]: Detail - Node: 0 Received: 0x01, 0x19, 0x00, 0x4a, 0x0b, 0x03, 0x03, 0x12, 0x04, 0x11, 0x01, 0x5e, 0x26, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5a, 0x73, 0x5b, 0x9f, 0x6c, 0x70, 0x22, 0x7a, 0x0d
2021-01-20 19:49:59.248727120 [20210120 19:49:59.248 UTC] [ozw.library] [info]: Info - Node: 0 FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2021-01-20 19:49:59.249358055 [20210120 19:49:59.248 UTC] [ozw.library] [info]: Info - Node: 0 ADD_NODE_STATUS_ADDING_SLAVE
2021-01-20 19:49:59.249959249 [20210120 19:49:59.249 UTC] [ozw.library] [info]: Info - Node: 0 Adding node ID 3 - Non-Secure
2021-01-20 19:49:59.250628665 [20210120 19:49:59.250 UTC] [ozw.library] [debug]: Detail - Node: 3 Notification: AddDevice ControllerCommand - InProgress
2021-01-20 19:49:59.251114066 [20210120 19:49:59.250 UTC] [ozw.notifications] [debug]: Notification pvt_controllerCommand 1 6 0 Thread: 0xb3c5f010
2021-01-20 19:49:59.251639558 [20210120 19:49:59.251 UTC] [ozw.mqtt.publisher] [debug]: Publishing Event controllerCommand 3 NotificationTypes::Ctrl_Cmd_AddNode NotificationTypes::Ctrl_State_InProgress NotificationTypes::Ctrl_Error_None
2021-01-20 19:49:59.687516547 [20210120 19:49:59.687 UTC] [ozw.library] [debug]: Detail - Node: 0 Received: 0x01, 0x07, 0x00, 0x4a, 0x0b, 0x05, 0x03, 0x00, 0xbf
2021-01-20 19:49:59.688432811 [20210120 19:49:59.687 UTC] [ozw.library] [info]: Info - Node: 0 FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2021-01-20 19:49:59.689157448 [20210120 19:49:59.688 UTC] [ozw.library] [info]: Info - Node: 0 ADD_NODE_STATUS_PROTOCOL_DONE
2021-01-20 19:49:59.689903770 [20210120 19:49:59.689 UTC] [ozw.library] [debug]: Detail - Node: 255 Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2021-01-20 19:49:59.690661518 [20210120 19:49:59.690 UTC] [ozw.library] [debug]: Detail - Node: 3 Notification: AddDevice ControllerCommand - InProgress
2021-01-20 19:49:59.691215936 [20210120 19:49:59.690 UTC] [ozw.notifications] [debug]: Notification pvt_controllerCommand 1 6 0 Thread: 0xb3c5f010
2021-01-20 19:49:59.691848019 [20210120 19:49:59.691 UTC] [ozw.library] [info]: Info - Node: 255 Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2021-01-20 19:49:59.691872315 [20210120 19:49:59.691 UTC] [ozw.mqtt.publisher] [debug]: Publishing Event controllerCommand 3 NotificationTypes::Ctrl_Cmd_AddNode NotificationTypes::Ctrl_State_InProgress NotificationTypes::Ctrl_Error_None
2021-01-20 19:49:59.693917173 [20210120 19:49:59.691 UTC] [ozw.library] [info]: Info - Node: 255 Encrypted Flag is 0
2021-01-20 19:49:59.746964659 [20210120 19:49:59.746 UTC] [ozw.library] [debug]: Detail - Node: 255 Received: 0x01, 0x07, 0x00, 0x4a, 0x0b, 0x06, 0x03, 0x00, 0xbc
2021-01-20 19:49:59.747856460 [20210120 19:49:59.747 UTC] [ozw.library] [info]: Info - Node: 255 FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2021-01-20 19:49:59.748554691 [20210120 19:49:59.747 UTC] [ozw.library] [info]: Info - Node: 255 ADD_NODE_STATUS_DONE
2021-01-20 19:49:59.749407289 [20210120 19:49:59.749 UTC] [ozw.library] [info]: Info - Node: 3 Network Key Not Set - Secure Option is not required
2021-01-20 19:49:59.749897485 [20210120 19:49:59.749 UTC] [ozw.library] [info]: Info - Node: 3 Basic device class (0x04) - Routing Slave
2021-01-20 19:49:59.750307239 [20210120 19:49:59.750 UTC] [ozw.library] [info]: Info - Node: 3 Generic device Class (0x11) - Multilevel Switch
2021-01-20 19:49:59.750943711 [20210120 19:49:59.750 UTC] [ozw.library] [info]: Info - Node: 3 Specific device class (0x01) - Multilevel Power Switch
2021-01-20 19:49:59.751375519 [20210120 19:49:59.751 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_BASIC will be mapped to COMMAND_CLASS_SWITCH_MULTILEVEL
2021-01-20 19:49:59.751801290 [20210120 19:49:59.751 UTC] [ozw.library] [info]: Info - Node: 3 Mandatory Command Classes for Node 3:
2021-01-20 19:49:59.752177137 [20210120 19:49:59.751 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_BASIC
2021-01-20 19:49:59.752615630 [20210120 19:49:59.752 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_SWITCH_MULTILEVEL
2021-01-20 19:49:59.752997587 [20210120 19:49:59.752 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_SWITCH_ALL
2021-01-20 19:49:59.753431747 [20210120 19:49:59.753 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_MANUFACTURER_SPECIFIC
2021-01-20 19:49:59.753806742 [20210120 19:49:59.753 UTC] [ozw.library] [info]: Info - Node: 3 Mandatory Command Classes controlled by Node 3:
2021-01-20 19:49:59.754242309 [20210120 19:49:59.753 UTC] [ozw.library] [info]: Info - Node: 3 None
2021-01-20 19:49:59.754634767 [20210120 19:49:59.754 UTC] [ozw.library] [info]: Info - Node: 3 Optional CommandClasses for node 3:
2021-01-20 19:49:59.755223573 [20210120 19:49:59.754 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_ZWAVEPLUS_INFO
2021-01-20 19:49:59.755521698 [20210120 19:49:59.755 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_SWITCH_MULTILEVEL (Existing)
2021-01-20 19:49:59.756097022 [20210120 19:49:59.755 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_ASSOCIATION
2021-01-20 19:49:59.756441721 [20210120 19:49:59.756 UTC] [ozw.library] [info]: Info - Node: 3 CommandClass 0x59 - NOT REQUIRED
2021-01-20 19:49:59.757039305 [20210120 19:49:59.756 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_VERSION
2021-01-20 19:49:59.757369522 [20210120 19:49:59.757 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_MANUFACTURER_SPECIFIC (Existing)
2021-01-20 19:49:59.757772479 [20210120 19:49:59.757 UTC] [ozw.library] [info]: Info - Node: 3 CommandClass 0x55 - NOT REQUIRED
2021-01-20 19:49:59.758121881 [20210120 19:49:59.757 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_DEVICE_RESET_LOCALLY
2021-01-20 19:49:59.758604041 [20210120 19:49:59.758 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_POWERLEVEL
2021-01-20 19:49:59.758959313 [20210120 19:49:59.758 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_CENTRAL_SCENE
2021-01-20 19:49:59.759312715 [20210120 19:49:59.759 UTC] [ozw.library] [info]: Info - Node: 3 CommandClass 0x9f - NOT REQUIRED
2021-01-20 19:49:59.759640247 [20210120 19:49:59.759 UTC] [ozw.library] [info]: Info - Node: 3 CommandClass 0x6c - NOT REQUIRED
2021-01-20 19:49:59.760119907 [20210120 19:49:59.759 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_CONFIGURATION
2021-01-20 19:49:59.760391495 [20210120 19:49:59.760 UTC] [ozw.library] [info]: Info - Node: 3 COMMAND_CLASS_APPLICATION_STATUS
2021-01-20 19:49:59.760872433 [20210120 19:49:59.760 UTC] [ozw.library] [info]: Info - Node: 3 CommandClass 0x7a - NOT REQUIRED
2021-01-20 19:49:59.761149114 [20210120 19:49:59.760 UTC] [ozw.library] [debug]: Detail - Node: 3 AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2021-01-20 19:49:59.761518460 [20210120 19:49:59.761 UTC] [ozw.library] [debug]: Detail - Node: 3 QueryStage_ProtocolInfo
2021-01-20 19:49:59.761898602 [20210120 19:49:59.761 UTC] [ozw.library] [debug]: Detail - Node: 3 Queuing (Query) Get Node Protocol Info (Node=3): 0x01, 0x04, 0x00, 0x41, 0x03, 0xb9
2021-01-20 19:49:59.762281375 [20210120 19:49:59.762 UTC] [ozw.library] [debug]: Detail - Node: 3 Queuing (Query) Query Stage Complete (ProtocolInfo)
2021-01-20 19:49:59.762609999 [20210120 19:49:59.762 UTC] [ozw.library] [info]: Info - Node: 3 Initializing Node. New Node: true (true)
2021-01-20 19:49:59.762986586 [20210120 19:49:59.762 UTC] [ozw.library] [debug]: Detail - Node: 255 Expected reply was received
2021-01-20 19:49:59.763300026 [20210120 19:49:59.763 UTC] [ozw.library] [debug]: Detail - Node: 255 Message transaction complete
2021-01-20 19:49:59.763653169 [20210120 19:49:59.763 UTC] [ozw.library] [debug]: Detail - Node: 255 Removing current message
2021-01-20 19:49:59.764001812 [20210120 19:49:59.763 UTC] [ozw.library] [debug]: Detail - Node: 3 Notification: NodeAdded
2021-01-20 19:49:59.764456361 [20210120 19:49:59.764 UTC] [ozw.library] [debug]: Detail - Node: 3 Notification: NodeProtocolInfo
2021-01-20 19:49:59.764960094 [20210120 19:49:59.764 UTC] [ozw.notifications] [debug]: Notification pvt_nodeAdded 3 Thread: 0xb3c5f010
2021-01-20 19:49:59.765161239 [20210120 19:49:59.764 UTC] [ozw.library] [debug]: Detail - Node: 3 Notification: AddDevice ControllerCommand - Completed
2021-01-20 19:49:59.765861858 [20210120 19:49:59.765 UTC] [ozw.nodes] [info]: Adding Node 3 At Row 2
2021-01-20 19:49:59.766070429 [20210120 19:49:59.765 UTC] [ozw.library] [info]: Info - Node: 0 Add Device
2021-01-20 19:49:59.766477460 [20210120 19:49:59.766 UTC] [ozw.library] [debug]: Detail - Node: 255 Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0c, 0x7d
2021-01-20 19:49:59.767145469 [20210120 19:49:59.766 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeQueryStage : QVariant(QString, "ProtocolInfo") Transaction: true
2021-01-20 19:49:59.767379243 [20210120 19:49:59.767 UTC] [ozw.library] [debug]: Detail - Node: 0 Notification: AddDevice ControllerCommand - Starting
2021-01-20 19:49:59.767855291 [20210120 19:49:59.767 UTC] [ozw.library] [info]: Info - Node: 255 Sending (Command) message (Callback ID=0x0c, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0c, 0x7d
2021-01-20 19:49:59.768143028 [20210120 19:49:59.767 UTC] [ozw.library] [info]: Info - Node: 255 Encrypted Flag is 0
2021-01-20 19:49:59.768904609 [20210120 19:49:59.768 UTC] [ozw.manager] [debug]: ProductPic Path: "/opt/ozw/config/"
2021-01-20 19:49:59.769529192 [20210120 19:49:59.769 UTC] [ozw.mqtt.publisher] [debug]: Publishing Event NodeAdded: 3
2021-01-20 19:49:59.770119665 [20210120 19:49:59.769 UTC] [ozw.notifications] [debug]: Notification pvt_nodeProtocolInfo 3 Thread: 0xb3c5f010
2021-01-20 19:49:59.770628639 [20210120 19:49:59.770 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeProductName : QVariant(QString, "") Transaction: true
2021-01-20 19:49:59.771143798 [20210120 19:49:59.770 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeManufacturerName : QVariant(QString, "") Transaction: true
2021-01-20 19:49:59.771377405 [20210120 19:49:59.771 UTC] [ozw.library] [debug]: Detail - Node: 255 Received: 0x01, 0x07, 0x00, 0x4a, 0x0c, 0x01, 0x00, 0x00, 0xbf
2021-01-20 19:49:59.772202060 [20210120 19:49:59.771 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeManufacturerID : QVariant(QString, "0x0000") Transaction: true
2021-01-20 19:49:59.772497870 [20210120 19:49:59.772 UTC] [ozw.library] [info]: Info - Node: 255 FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2021-01-20 19:49:59.773144620 [20210120 19:49:59.772 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeProductID : QVariant(QString, "0x0000") Transaction: true
2021-01-20 19:49:59.773359505 [20210120 19:49:59.773 UTC] [ozw.library] [info]: Info - Node: 255 ADD_NODE_STATUS_LEARN_READY
2021-01-20 19:49:59.774001551 [20210120 19:49:59.773 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeProductType : QVariant(QString, "0x0000") Transaction: true
2021-01-20 19:49:59.774214826 [20210120 19:49:59.773 UTC] [ozw.library] [debug]: Detail - Node: 255 Expected callbackId was received
2021-01-20 19:49:59.774861316 [20210120 19:49:59.774 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeBasicString : QVariant(QString, "Routing Slave") Transaction: true
2021-01-20 19:49:59.775072109 [20210120 19:49:59.774 UTC] [ozw.library] [debug]: Detail - Node: 255 Expected reply was received
2021-01-20 19:49:59.775470344 [20210120 19:49:59.775 UTC] [ozw.library] [debug]: Detail - Node: 255 Message transaction complete
2021-01-20 19:49:59.776022540 [20210120 19:49:59.775 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeBasic : QVariant(int, 4) Transaction: true
2021-01-20 19:49:59.776228259 [20210120 19:49:59.775 UTC] [ozw.library] [debug]: Detail - Node: 255 Removing current message
2021-01-20 19:49:59.776644178 [20210120 19:49:59.776 UTC] [ozw.library] [debug]: Detail - Node: 0 Notification: AddDevice ControllerCommand - Waiting
2021-01-20 19:49:59.777304891 [20210120 19:49:59.776 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeGenericString : QVariant(QString, "Multilevel Switch") Transaction: true
2021-01-20 19:49:59.777542110 [20210120 19:49:59.777 UTC] [ozw.library] [info]: Info - Node: 0 WriteNextMsg Controller nothing to do
2021-01-20 19:49:59.778329635 [20210120 19:49:59.777 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeGeneric : QVariant(int, 17) Transaction: true
2021-01-20 19:49:59.778795350 [20210120 19:49:59.778 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeSpecific : QVariant(int, 1) Transaction: true
2021-01-20 19:49:59.779303991 [20210120 19:49:59.778 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeSpecificString : QVariant(QString, "Multilevel Power Switch") Transaction: true
2021-01-20 19:49:59.779762428 [20210120 19:49:59.779 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeBaudRate : QVariant(uint, 0) Transaction: true
2021-01-20 19:49:59.780273828 [20210120 19:49:59.779 UTC] [ozw.nodes] [debug]: setNodeData 3 : QTOZW_Nodes::NodeVersion : QVariant(int, 0) Transaction: true
2021-01-20 19:49:59.781371923 [20210120 19:49:59.781 UTC] [ozw.mqtt.publisher] [debug]: Publishing Event nodeProtocolInfo: 3
2021-01-20 19:49:59.781882100 [20210120 19:49:59.781 UTC] [ozw.notifications] [debug]: Notification pvt_controllerCommand 1 7 0 Thread: 0xb3c5f010
2021-01-20 19:49:59.782423574 [20210120 19:49:59.781 UTC] [ozw.mqtt.publisher] [debug]: Publishing Event controllerCommand 3 NotificationTypes::Ctrl_Cmd_AddNode NotificationTypes::Ctrl_State_Completed NotificationTypes::Ctrl_Error_None
2021-01-20 19:49:59.782939047 [20210120 19:49:59.782 UTC] [ozw.notifications] [debug]: Notification pvt_controllerCommand 1 1 0 Thread: 0xb3c5f010
2021-01-20 19:49:59.783478928 [20210120 19:49:59.783 UTC] [ozw.mqtt.publisher] [debug]: Publishing Event controllerCommand 0 NotificationTypes::Ctrl_Cmd_AddNode NotificationTypes::Ctrl_State_Starting NotificationTypes::Ctrl_Error_None
2021-01-20 19:49:59.785777987 [20210120 19:49:59.784 UTC] [ozw.notifications] [debug]: Notification pvt_controllerCommand 1 4 0 Thread: 0xb3c5f010
2021-01-20 19:49:59.788951532 [20210120 19:49:59.787 UTC] [ozw.mqtt.publisher] [debug]: Publishing Event controllerCommand 0 NotificationTypes::Ctrl_Cmd_AddNode NotificationTypes::Ctrl_State_Waiting NotificationTypes::Ctrl_Error_None
To my novice eyes, it looks like it onboarded correctly. But when I go to the node list in Home Assistant (Configuration -> Integrations -> OpenZWave (Beta) -> Configure -> Nodes) I see one filled entry for the Z-Wave USB adapter plugged into my Pi, and then two blank entries, I believe one for each time I tried adding the dimmer switch.
When I click on one of the blank entries, all it gives me for information is the NodeId. Nothing else. Again I am very new to this so I have no idea how I’m supposed to get from here to controlling the dimmer switch from HA.
I would greatly appreciate any help y’all are able to give. Let me know if there is any other information that I should post here.
