LarsAC
(Lars)
April 8, 2020, 9:02pm
1
I seem to have lost a couple of ZWave nodes in HA. Under entities tab, the ZWave controller pretends to have following neighbours:
neighbors: 4,6,8,10,16,17,18,19,20,21,22,23,24,25
whereas I can only see entity information for 16, 17, 19, 21 in UI or entities list.
Any ideas what might have happened ? I also found a new zwcfg_xxx.xml in my /config directory - could this be related ?
I am running 0.105.3 as a docker container.
Lars
tmjpugh
(Tmjpugh)
April 9, 2020, 6:01am
2
Yes
It this was deleted it. Hanged you would lose entities.
Have and old backup?
LarsAC
(Lars)
April 9, 2020, 6:18am
3
Yes, I have a backup. But the newly generated file also has a new name. So should I copy the contents of the old file into the new one?
Why did the name change?
Lars
tmjpugh
(Tmjpugh)
April 9, 2020, 3:20pm
4
Usually that happen when zwave remove and readded but I not know details of that.
You can try both ways…add to file and replace with file. Before you do anything rlse, stop HA and backup zwave stick( if aeotech there is backup software on their site)
