hi everyone,i have a terrible problem. i can use any help .
i have a raspi 4 with home assistant installed i have a usbz1 zwave and zigbee usb stick configured but try as i might i can not get home assistant to open a kwikset lock.
here is the log file
2020-12-17 11:09:46.218 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2020-12-17 11:09:46.218 Info, contrlr, Node 001 - Known
2020-12-17 11:09:46.218 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-12-17 11:09:46.218 Detail, Node001, QueryStage_CacheLoad
2020-12-17 11:09:46.218 Info, Node001, Node Identity Codes: 0000:0001:0001
2020-12-17 11:09:46.218 Detail, Node001, QueryStage_Associations
2020-12-17 11:09:46.218 Detail, Node001, QueryStage_Neighbors
2020-12-17 11:09:46.218 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2020-12-17 11:09:46.218 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-12-17 11:09:46.218 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2020-12-17 11:09:46.218 Info, contrlr, Node 003 - Known
2020-12-17 11:09:46.218 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-12-17 11:09:46.218 Detail, Node003, QueryStage_CacheLoad
2020-12-17 11:09:46.218 Info, Node003, Node Identity Codes: 0090:0003:0541
2020-12-17 11:09:46.219 Info, Node003, NoOperation::Set - Routing=true
2020-12-17 11:09:46.219 Detail, Node003, Queuing (NoOp) NoOperation_Set (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xcb
2020-12-17 11:09:46.219 Detail, Node003, Queuing (Query) Query Stage Complete (CacheLoad)
2020-12-17 11:09:46.219 Detail, Node008, Expected reply was received
2020-12-17 11:09:46.219 Detail, Node008, Message transaction complete
2020-12-17 11:09:46.219 Detail, contrlr, Removing current message
2020-12-17 11:09:46.219 Detail, Node001, Notification: DriverReady
2020-12-17 11:09:46.220 Detail, Node001, Notification: NodeAdded
2020-12-17 11:09:46.223 Detail, Node001, Notification: NodeProtocolInfo
2020-12-17 11:09:46.224 Detail, Node001, Notification: EssentialNodeQueriesComplete
2020-12-17 11:09:46.224 Detail, Node001, Notification: ValueAdded
2020-12-17 11:09:46.225 Detail, Node003, Notification: NodeAdded
2020-12-17 11:09:46.227 Detail, Node003, Notification: NodeProtocolInfo
2020-12-17 11:09:46.227 Detail, Node003, Notification: EssentialNodeQueriesComplete
2020-12-17 11:09:46.227 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.228 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.229 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.231 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.233 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.237 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.240 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.241 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.242 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.243 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.244 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.245 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.246 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.247 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.248 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.249 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.250 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.251 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.254 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.255 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.258 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.259 Detail, Node003, Notification: ValueAdded
2020-12-17 11:09:46.259 Detail, Node003, Notification: NodeNaming
2020-12-17 11:09:46.260 Detail,
2020-12-17 11:09:46.260 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-12-17 11:09:46.262 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2020-12-17 11:09:46.262 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2020-12-17 11:09:46.262 Detail, Node015, Expected reply was received
2020-12-17 11:09:46.262 Detail, Node015, Message transaction complete
2020-12-17 11:09:46.262 Detail, contrlr, Removing current message
2020-12-17 11:09:46.262 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-12-17 11:09:46.264 Detail, contrlr, Removing current message
2020-12-17 11:09:46.264 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-12-17 11:09:46.269 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5a
2020-12-17 11:09:46.269 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-12-17 11:09:46.269 Info, Node001, Neighbors of this node are:
2020-12-17 11:09:46.269 Info, Node001, Node 3
2020-12-17 11:09:46.269 Detail, Expected reply was received
2020-12-17 11:09:46.269 Detail, Message transaction complete
2020-12-17 11:09:46.269 Detail, Node001, Removing current message
2020-12-17 11:09:46.269 Info, Node003, Sending (NoOp) message (Callback ID=0x0a, Expected Reply=0x13) - NoOperation_Set (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xcb
2020-12-17 11:09:46.275 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-17 11:09:46.275 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-17 11:09:47.505 Detail, Node003, Received: 0x01, 0x05, 0x00, 0x13, 0x0a, 0x00, 0xe3
2020-12-17 11:09:47.505 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2020-12-17 11:09:47.505 Info, Node003, Request RTT 1235 Average Request RTT 1235
2020-12-17 11:09:47.505 Detail, Expected callbackId was received
2020-12-17 11:09:47.505 Detail, Expected reply was received
2020-12-17 11:09:47.506 Detail, Message transaction complete
2020-12-17 11:09:47.506 Detail, Node003, Removing current message
2020-12-17 11:09:47.506 Detail, Node003, Notification: Notification - NoOperation
2020-12-17 11:09:47.521 Detail, Node001, Query Stage Complete (Neighbors)
2020-12-17 11:09:47.521 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2020-12-17 11:09:47.521 Detail, Node001, QueryStage_Session
2020-12-17 11:09:47.521 Detail, Node001, QueryStage_Dynamic
2020-12-17 11:09:47.521 Detail, Node001, QueryStage_Configuration
2020-12-17 11:09:47.521 Detail, Node001, QueryStage_Complete
2020-12-17 11:09:47.521 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-12-17 11:09:47.521 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2020-12-17 11:09:47.521 Info, Node query processing complete except for sleeping nodes.
2020-12-17 11:09:47.521 Detail, Node001, Notification: NodeQueriesComplete
2020-12-17 11:09:47.523 Detail, contrlr, Notification: AwakeNodesQueried
2020-12-17 11:09:47.525 Detail, Node003, Query Stage Complete (CacheLoad)
2020-12-17 11:09:47.525 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
2020-12-17 11:09:47.525 Detail, Node003, QueryStage_Associations
2020-12-17 11:09:47.525 Info, Node003, Number of association groups reported for node 3 is 0.
2020-12-17 11:09:47.525 Info, Node003, Get Associations for group 1 of node 3
2020-12-17 11:09:47.525 Detail, Node003, Queuing (Send) AssociationCmd_Get (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x85, 0x02, 0x01, 0x25, 0x0b, 0x4e
2020-12-17 11:09:47.525 Detail, Node003, Queuing (Query) Query Stage Complete (Associations)
2020-12-17 11:09:47.525 Info, Node003, Sending (Send) message (Callback ID=0x0b, Expected Reply=0x04) - AssociationCmd_Get (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x85, 0x02, 0x01, 0x25, 0x0b, 0x4e
2020-12-17 11:09:47.531 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-17 11:09:47.531 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-17 11:09:47.550 Detail, Node003, Received: 0x01, 0x05, 0x00, 0x13, 0x0b, 0x00, 0xe2
2020-12-17 11:09:47.550 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2020-12-17 11:09:47.551 Info, Node003, Request RTT 25 Average Request RTT 630
2020-12-17 11:09:47.551 Detail, Expected callbackId was received
2020-12-17 11:09:57.526 Error, Node003, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-17 11:09:57.526 Detail, Node003, Removing current message
2020-12-17 11:09:57.526 Detail, Node003, Notification: Notification - TimeOut
2020-12-17 11:09:57.528 Detail, Node003, Query Stage Complete (Associations)
2020-12-17 11:09:57.528 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Neighbors live=1
2020-12-17 11:09:57.528 Detail, Node003, QueryStage_Neighbors
2020-12-17 11:09:57.528 Detail, Requesting routing info (neighbor list) for Node 3
2020-12-17 11:09:57.528 Detail, Node003, Queuing (Command) Get Routing Info (Node=3): 0x01, 0x07, 0x00, 0x80, 0x03, 0x00, 0x00, 0x03, 0x78
2020-12-17 11:09:57.528 Detail, Node003, Queuing (Query) Query Stage Complete (Neighbors)
2020-12-17 11:09:57.529 Info, Node003, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=3): 0x01, 0x07, 0x00, 0x80, 0x03, 0x00, 0x00, 0x03, 0x78
2020-12-17 11:09:57.534 Detail, Node003, Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5f
2020-12-17 11:09:57.534 Info, Node003, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-12-17 11:09:57.535 Info, Node003, Neighbors of this node are:
2020-12-17 11:09:57.535 Info, Node003, Node 1
2020-12-17 11:09:57.535 Detail, Expected reply was received
2020-12-17 11:09:57.535 Detail, Message transaction complete
2020-12-17 11:09:57.535 Detail, Node003, Removing current message
2020-12-17 11:09:57.535 Detail, Node003, Query Stage Complete (Neighbors)
2020-12-17 11:09:57.535 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2020-12-17 11:09:57.535 Detail, Node003, QueryStage_Session
2020-12-17 11:09:57.535 Detail, Node003, Queuing (Query) PowerlevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x73, 0x02, 0x25, 0x0c, 0xbc
2020-12-17 11:09:57.535 Detail, Node003, Queuing (Query) Query Stage Complete (Session)
2020-12-17 11:09:57.535 Info, Node003, Sending (Query) message (Callback ID=0x0c, Expected Reply=0x04) - PowerlevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x73, 0x02, 0x25, 0x0c, 0xbc
2020-12-17 11:09:57.541 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-17 11:09:57.541 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-17 11:09:58.786 Detail, Node003, Received: 0x01, 0x05, 0x00, 0x13, 0x0c, 0x00, 0xe5
2020-12-17 11:09:58.786 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2020-12-17 11:09:58.786 Info, Node003, Request RTT 1250 Average Request RTT 940
2020-12-17 11:09:58.786 Detail, Expected callbackId was received
2020-12-17 11:09:58.798 Detail, Node003, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x03, 0x04, 0x73, 0x03, 0x00, 0x00, 0x86
2020-12-17 11:09:58.799 Detail,
2020-12-17 11:09:58.799 Info, Node003, Response RTT 1263 Average Response RTT 1263
2020-12-17 11:09:58.799 Info, Node003, Received a PowerLevel report: PowerLevel=Normal, Timeout=0
2020-12-17 11:09:58.799 Detail, Node003, Initial read of value
2020-12-17 11:09:58.799 Detail, Node003, Expected reply and command class was received
2020-12-17 11:09:58.799 Detail, Node003, Message transaction complete
2020-12-17 11:09:58.799 Detail, Node003, Removing current message
2020-12-17 11:09:58.799 Detail, Node003, Notification: ValueChanged
2020-12-17 11:09:58.801 Detail, Node003, Notification: ValueChanged
2020-12-17 11:09:58.803 Detail, Node003, Query Stage Complete (Session)
2020-12-17 11:09:58.803 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2020-12-17 11:09:58.803 Detail, Node003, QueryStage_Dynamic
2020-12-17 11:09:58.803 Detail, Node003, Queuing (Send) DoorLockCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x62, 0x02, 0x25, 0x0d, 0xac
2020-12-17 11:09:58.803 Detail, Node003, Queuing (Send) BatteryCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x80, 0x02, 0x25, 0x0e, 0x4d
2020-12-17 11:09:58.803 Detail, Node003, Queuing (Query) Query Stage Complete (Dynamic)
2020-12-17 11:09:58.804 Detail,
2020-12-17 11:09:58.804 Info, Node003, Sending (Send) message (Callback ID=0x0d, Expected Reply=0x04) - DoorLockCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x62, 0x02, 0x25, 0x0d, 0xac
2020-12-17 11:09:58.809 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-17 11:09:58.809 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-17 11:09:58.828 Detail, Node003, Received: 0x01, 0x05, 0x00, 0x13, 0x0d, 0x00, 0xe4
2020-12-17 11:09:58.829 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x0d received (expected 0x0d)
2020-12-17 11:09:58.829 Info, Node003, Request RTT 24 Average Request RTT 482
2020-12-17 11:09:58.829 Detail, Expected callbackId was received
2020-12-17 11:10:08.804 Error, Node003, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-17 11:10:08.804 Detail, Node003, Removing current message
2020-12-17 11:10:08.804 Detail, Node003, Notification: Notification - TimeOut
2020-12-17 11:10:08.806 Detail,
2020-12-17 11:10:08.806 Info, Node003, Sending (Send) message (Callback ID=0x0e, Expected Reply=0x04) - BatteryCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x80, 0x02, 0x25, 0x0e, 0x4d
2020-12-17 11:10:08.812 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-17 11:10:08.812 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-17 11:10:10.087 Detail, Node003, Received: 0x01, 0x05, 0x00, 0x13, 0x0e, 0x00, 0xe7
2020-12-17 11:10:10.088 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x0e received (expected 0x0e)
2020-12-17 11:10:10.088 Info, Node003, Request RTT 1282 Average Request RTT 882
2020-12-17 11:10:10.088 Detail, Expected callbackId was received
2020-12-17 11:10:18.806 Error, Node003, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-17 11:10:18.806 Detail, Node003, Removing current message
2020-12-17 11:10:18.806 Detail, Node003, Notification: Notification - TimeOut
2020-12-17 11:10:18.808 Detail, Node003, Query Stage Complete (Dynamic)
2020-12-17 11:10:18.808 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2020-12-17 11:10:18.808 Detail, Node003, QueryStage_Configuration
2020-12-17 11:10:18.808 Detail, Node003, QueryStage_Complete
2020-12-17 11:10:18.808 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=1
2020-12-17 11:10:18.808 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2020-12-17 11:10:18.808 Info, Node query processing complete.
2020-12-17 11:10:18.809 Detail, Node003, Notification: NodeQueriesComplete
not a programmer but seems problem is,
can anyone point me in the right direction any help would be appreciated
