I think it worked anyway. Only 1 lock stopped working but now itâs back. I am going to check it more thoroughly in the morning, but so far so good.
If I do a HAconfiguration check on 107.7 I do still receive a zwave error:
INFO:homeassistant.util.package:Attempting install of homeassistant-pyozw==0.1.10
ERROR:homeassistant.util.package:Unable to install package homeassistant-pyozw==0.1.10: ERROR: Command errored out with exit status 1:
command: /usr/local/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-yl9m_8l0/homeassistant-pyozw/setup.py'"'"'; __file__='"'"'/tmp/pip-install-yl9m_8l0/homeassistant-pyozw/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-8vrsdlcg --python-tag cp37
cwd: /tmp/pip-install-yl9m_8l0/homeassistant-pyozw/
Complete output (17 lines):
sysargv ['/tmp/pip-install-yl9m_8l0/homeassistant-pyozw/setup.py', 'bdist_wheel', '-d', '/tmp/pip-wheel-8vrsdlcg', '--python-tag', 'cp37']
Found SETUP_DIR : /tmp/pip-install-yl9m_8l0/homeassistant-pyozw
<pyozw_setup.EmbedTemplate object at 0x7f91892290>
{'name': 'libopenzwave', 'sources': ['openzwave-embed/open-zwave-hass/python-openzwave/src-lib/libopenzwave/libopenzwave.cpp'], 'include_dirs': ['src-lib/libopenzwave/', 'openzwave-embed/open-zwave-hass/cpp/src', 'openzwave-embed/open-zwave-hass/cpp/src/value_classes', 'openzwave-embed/open-zwave-hass/cpp/src/platform', 'openzwave-embed/open-zwave-hass/cpp/build/linux'], 'define_macros': [('PY_LIB_VERSION', '0.1.10'), ('PY_SSIZE_T_CLEAN', 1), ('PY_LIB_FLAVOR', 'embed'), ('PY_LIB_BACKEND', 'cpp')], 'libraries': ['udev', 'stdc++', 'resolv'], 'extra_objects': ['openzwave-embed/open-zwave-hass/libopenzwave.a'], 'extra_compile_args': [], 'extra_link_args': [], 'language': 'c++'}
['six', 'PyDispatcher>=2.0.5']
running bdist_wheel
running build
running build_openzwave
Found g++ : None
Found gcc : None
Found make : None
Found gmake : None
Found cython : None
Found pkg-config : None
fetching https://raw.githubusercontent.com/home-assistant/python-openzwave/hass/archives/open-zwave-hass-0.1.10.zip into openzwave-embed/open-zwave.zip for version 0.1.10
Clean openzwave in openzwave-embed/open-zwave-hass ... be patient ...
error: [Errno 2] No such file or directory: 'make': 'make'
ERROR: Failed building wheel for homeassistant-pyozw
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all
Complete output (8 lines):
sysargv ['/tmp/pip-install-yl9m_8l0/homeassistant-pyozw/setup.py', 'clean', '--all']
<pyozw_setup.EmbedTemplate object at 0x7f991842d0>
running clean
ERROR: Failed cleaning build dir for homeassistant-pyozw
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-1n1fi340/install-record.txt --single-version-externally-managed --compile
Complete output (16 lines):
sysargv ['/tmp/pip-install-yl9m_8l0/homeassistant-pyozw/setup.py', 'install', '--record', '/tmp/pip-record-1n1fi340/install-record.txt', '--single-version-externally-managed', '--compile']
<pyozw_setup.EmbedTemplate object at 0x7fa9042450>
running install
flavor embed
Found g++ : None
Found gcc : None
Found make : None
Found gmake : None
Found cython : None
ERROR: Command errored out with exit status 1: /usr/local/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-yl9m_8l0/homeassistant-pyozw/setup.py'"'"'; __file__='"'"'/tmp/pip-install-yl9m_8l0/homeassistant-pyozw/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-1n1fi340/install-record.txt --single-version-externally-managed --compile Check the logs for full command output.
WARNING: You are using pip version 19.2.2, however version 20.0.2 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
INFO:homeassistant.util.package:Attempting install of mutagen==1.43.0
INFO:homeassistant.util.package:Attempting install of gTTS-token==1.1.3
Failed config
General Errors:
- Component error: zwave - Requirements for zwave not found: ['homeassistant-pyozw==0.1.10'].
Successful config (partial)
So I still donât dare to go over on 107.7
If youâre using the docker image youâll be fine thereâs a wheel for homeassistant-pyozw
and you wonât have to compile your own.
Make sure you do a snapshot. If you want to be extra careful, shut down zwave first so the zwave config file is not in memory (Thank you to the person who told me this tip).
Once you have a good snapshot so you can restore if it doesnât work, you can attempt the upgrade.
Mine did work despite all the errorsâŚ
I was forced to go to 0.107.7 because the add-on store was disapeared after upgrade off supervisor to 213.
I do have NO zwave problems.
So Iâm happy
