Zwave options
I have a question, all the examples of setup Home Assistant whether on PI or PC has the Zwave connected direct through USB so in the config it is attach device. I have router that has Zwave and Zigbee can I still use Home Assistant?
Thank You
What router? how does it expose those radios? does it support mqtt?
The company is Securifi they have two routers the almound + almound 3. I don’t know about mqtt, I am new to this I was hoping that you could just define the ip of the router in the config sorry yaml file since it is in the same sub net. Also know of two media hubs that will be supporting zwave devices
So it sounds like somebody was taking a look at it. We’d likely have to do some work in order to bring it in and have it work correctly since it’s using an API. Might be worth taking a look at that feature request and asking if there have been any updates.
So I guess that’s a no then I’m glad that I asked, so the Veralite would be out then to. Thanks for the fast response…
