After running HASS for years and year (started with .22) I suddenly have a Zwave issue I can’t seem to crack. Overnight most of my zwave devices are not responding anymore. Only about 6 of my total +30 devices are working. The are others not.
I did not change anything to either hard or software. Running. 107.7 , HassIO on an Intel NUC. aeotec zwave gen5 stick.
What have tried:
- Healing network
- Resetting stick (via hass interface)
- Restored to several days before I had this issue
Attached partial log:
2020-04-11 17:19:59.124 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0xa2, 0x01, 0x0d, 0x6f, 0x2a
2020-04-11 17:19:59.124 Detail, ZW_SEND_DATA Request with callback ID 0xa2 received (expected 0x00)
2020-04-11 17:19:59.124 Warning, WARNING: Unexpected Callback ID received
2020-04-11 17:20:08.379 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:20:08.379 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa3, 0x7a
2020-04-11 17:20:08.379 Info, Node046, Sending (Poll) message (Callback ID=0xa3, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa3, 0x7a
2020-04-11 17:20:09.380 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:20:09.380 Detail, Node046, Removing current message
2020-04-11 17:20:09.380 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:21:09.389 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:21:09.390 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa4, 0x7d
2020-04-11 17:21:09.390 Info, Node046, Sending (Poll) message (Callback ID=0xa4, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa4, 0x7d
2020-04-11 17:21:10.390 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:21:10.390 Detail, Node046, Removing current message
2020-04-11 17:21:10.390 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:21:34.272 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x00, 0xe9
2020-04-11 17:21:34.272 Error, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-04-11 17:21:34.274 Detail, CAN received...triggering resend
2020-04-11 17:21:34.274 Warning, m_currentMsg was NULL when trying to set MaxSendAttempts
2020-04-11 17:21:34.274 Always,
2020-04-11 17:21:34.274 Always, Dumping queued log messages
2020-04-11 17:21:34.274 Always, End of queued log message dump
2020-04-11 17:21:34.274 Detail, WriteMsg CAN m_currentMsg=00000000
2020-04-11 17:21:34.275 Detail, Node009, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x09, 0x0a, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xcd
2020-04-11 17:21:34.275 Detail, Node009, Refreshed Value: old value=false, new value=false, type=bool
2020-04-11 17:21:34.275 Detail, Node009, Changes to this value are not verified
2020-04-11 17:21:34.275 Info, Node009, Received Meter report from node 9: Power=0.0W
2020-04-11 17:21:34.275 Detail, Node009, Refreshed Value: old value=0.1, new value=0.0, type=decimal
2020-04-11 17:21:34.275 Detail, Node009, Notification: ValueChanged
2020-04-11 17:21:34.294 Detail, Node009, Notification: ValueChanged
2020-04-11 17:22:10.400 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:22:10.400 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa5, 0x7c
2020-04-11 17:22:10.400 Info, Node046, Sending (Poll) message (Callback ID=0xa5, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa5, 0x7c
2020-04-11 17:22:11.401 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:22:11.401 Detail, Node046, Removing current message
2020-04-11 17:22:11.401 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:22:22.475 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-11 17:22:22.475 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-11 17:23:11.411 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:23:11.411 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa6, 0x7f
2020-04-11 17:23:11.411 Info, Node046, Sending (Poll) message (Callback ID=0xa6, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa6, 0x7f
2020-04-11 17:23:12.411 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:23:12.411 Detail, Node046, Removing current message
2020-04-11 17:23:12.411 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:24:12.421 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:24:12.421 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa7, 0x7e
2020-04-11 17:24:12.421 Info, Node046, Sending (Poll) message (Callback ID=0xa7, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa7, 0x7e
2020-04-11 17:24:13.421 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:24:13.421 Detail, Node046, Removing current message
2020-04-11 17:24:13.422 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:24:32.062 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x00, 0xe9
2020-04-11 17:24:32.062 Error, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-04-11 17:24:32.065 Detail, CAN received...triggering resend
2020-04-11 17:24:32.065 Warning, m_currentMsg was NULL when trying to set MaxSendAttempts
2020-04-11 17:24:32.065 Always,
2020-04-11 17:24:32.065 Always, Dumping queued log messages
2020-04-11 17:24:32.065 Always, End of queued log message dump
2020-04-11 17:24:32.065 Detail, WriteMsg CAN m_currentMsg=00000000
2020-04-11 17:24:32.181 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0xa6, 0x01, 0x00, 0x0c, 0x40
2020-04-11 17:24:32.181 Detail, ZW_SEND_DATA Request with callback ID 0xa6 received (expected 0x00)
2020-04-11 17:24:32.181 Warning, WARNING: Unexpected Callback ID received
2020-04-11 17:25:13.430 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:25:13.430 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa8, 0x71
2020-04-11 17:25:13.431 Detail,
2020-04-11 17:25:13.431 Info, Node046, Sending (Poll) message (Callback ID=0xa8, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa8, 0x71
2020-04-11 17:25:14.431 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:25:14.431 Detail, Node046, Removing current message
2020-04-11 17:25:14.431 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:25:20.219 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-11 17:25:20.219 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-11 17:25:54.627 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0xa8, 0x01, 0x0d, 0x72, 0x3d
2020-04-11 17:25:54.627 Detail, ZW_SEND_DATA Request with callback ID 0xa8 received (expected 0x00)
2020-04-11 17:25:54.628 Warning, WARNING: Unexpected Callback ID received
2020-04-11 17:26:14.441 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:26:14.441 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa9, 0x70
2020-04-11 17:26:14.441 Info, Node046, Sending (Poll) message (Callback ID=0xa9, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xa9, 0x70
2020-04-11 17:26:15.442 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:26:15.442 Detail, Node046, Removing current message
2020-04-11 17:26:15.442 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:27:15.451 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:27:15.451 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xaa, 0x73
2020-04-11 17:27:15.451 Info, Node046, Sending (Poll) message (Callback ID=0xaa, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xaa, 0x73
2020-04-11 17:27:16.452 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:27:16.452 Detail, Node046, Removing current message
2020-04-11 17:27:16.452 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:27:29.775 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x00, 0xe9
2020-04-11 17:27:29.775 Error, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-04-11 17:27:29.777 Detail, CAN received...triggering resend
2020-04-11 17:27:29.777 Warning, m_currentMsg was NULL when trying to set MaxSendAttempts
2020-04-11 17:27:29.777 Always,
2020-04-11 17:27:29.778 Always, Dumping queued log messages
2020-04-11 17:27:29.778 Always, End of queued log message dump
2020-04-11 17:27:29.778 Detail, WriteMsg CAN m_currentMsg=00000000
2020-04-11 17:28:16.461 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:28:16.461 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xab, 0x72
2020-04-11 17:28:16.462 Detail,
2020-04-11 17:28:16.462 Info, Node046, Sending (Poll) message (Callback ID=0xab, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xab, 0x72
2020-04-11 17:28:17.462 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:28:17.463 Detail, Node046, Removing current message
2020-04-11 17:28:17.463 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:28:17.928 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-11 17:28:17.929 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-11 17:28:52.307 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0xab, 0x01, 0x0d, 0x6f, 0x23
2020-04-11 17:28:52.308 Detail, ZW_SEND_DATA Request with callback ID 0xab received (expected 0x00)
2020-04-11 17:28:52.308 Warning, WARNING: Unexpected Callback ID received
2020-04-11 17:29:17.470 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:29:17.470 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xac, 0x75
2020-04-11 17:29:17.471 Info, Node046, Sending (Poll) message (Callback ID=0xac, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xac, 0x75
2020-04-11 17:29:18.471 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:29:18.471 Detail, Node046, Removing current message
2020-04-11 17:29:18.471 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:30:18.477 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:30:18.477 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xad, 0x74
2020-04-11 17:30:18.478 Detail,
2020-04-11 17:30:18.478 Info, Node046, Sending (Poll) message (Callback ID=0xad, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xad, 0x74
2020-04-11 17:30:19.478 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:30:19.478 Detail, Node046, Removing current message
2020-04-11 17:30:19.478 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:30:27.539 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x00, 0xe9
2020-04-11 17:30:27.539 Error, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-04-11 17:30:27.541 Detail, CAN received...triggering resend
2020-04-11 17:30:27.541 Warning, m_currentMsg was NULL when trying to set MaxSendAttempts
2020-04-11 17:30:27.541 Always,
2020-04-11 17:30:27.541 Always, Dumping queued log messages
2020-04-11 17:30:27.541 Always, End of queued log message dump
2020-04-11 17:30:27.541 Detail, WriteMsg CAN m_currentMsg=00000000
2020-04-11 17:31:19.480 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:31:19.480 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xae, 0x77
2020-04-11 17:31:19.480 Info, Node046, Sending (Poll) message (Callback ID=0xae, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xae, 0x77
2020-04-11 17:31:20.480 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:31:20.480 Detail, Node046, Removing current message
2020-04-11 17:31:20.480 Detail, Node046, Notification: Notification - TimeOut
2020-04-11 17:31:43.042 Info, Node040, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2020-04-11 17:31:43.042 Detail, Node040, Refreshed Value: old value=255, new value=255, type=byte
2020-04-11 17:31:43.042 Detail, Node040, Changes to this value are not verified
2020-04-11 17:31:43.042 Detail, Node040, Notification: ValueChanged
2020-04-11 17:31:43.044 Info, Node040, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 255
2020-04-11 17:31:43.044 Info, Node040, SwitchMultilevel::Set - Setting to level 255
2020-04-11 17:31:43.044 Info, Node040, Duration: Default
2020-04-11 17:31:43.044 Detail, Node040, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=40): 0x01, 0x0f, 0x00, 0x13, 0x28, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0xff, 0xff, 0x25, 0xaf, 0x03
2020-04-11 17:31:43.044 Detail, Node040, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=40): 0x01, 0x0d, 0x00, 0x13, 0x28, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0xb0, 0x13
2020-04-11 17:31:43.062 Detail,
2020-04-11 17:31:43.062 Info, Node040, Sending (Send) message (Callback ID=0xaf, Expected Reply=0x13) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=40): 0x01, 0x0f, 0x00, 0x13, 0x28, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0xff, 0xff, 0x25, 0xaf, 0x03
2020-04-11 17:31:44.063 Error, Node040, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:31:44.063 Detail, Node040, Removing current message
2020-04-11 17:31:44.063 Detail, Node040, Notification: Notification - TimeOut
2020-04-11 17:31:44.072 Detail,
2020-04-11 17:31:44.073 Info, Node040, Sending (Send) message (Callback ID=0xb0, Expected Reply=0x04) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=40): 0x01, 0x0d, 0x00, 0x13, 0x28, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0xb0, 0x13
2020-04-11 17:31:45.073 Error, Node040, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:31:45.073 Detail, Node040, Removing current message
2020-04-11 17:31:45.073 Detail, Node040, Notification: Notification - TimeOut
2020-04-11 17:31:48.366 Info, Node040, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2020-04-11 17:31:48.366 Detail, Node040, Refreshed Value: old value=255, new value=255, type=byte
2020-04-11 17:31:48.366 Detail, Node040, Changes to this value are not verified
2020-04-11 17:31:48.366 Detail, Node040, Notification: ValueChanged
2020-04-11 17:31:48.367 Info, Node040, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 29
2020-04-11 17:31:48.367 Info, Node040, SwitchMultilevel::Set - Setting to level 29
2020-04-11 17:31:48.368 Info, Node040, Duration: Default
2020-04-11 17:31:48.368 Detail, Node040, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=40): 0x01, 0x0f, 0x00, 0x13, 0x28, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0x1d, 0xff, 0x25, 0xb1, 0xff
2020-04-11 17:31:48.368 Detail, Node040, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=40): 0x01, 0x0d, 0x00, 0x13, 0x28, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0xb2, 0x11
2020-04-11 17:31:48.384 Detail,
2020-04-11 17:31:48.384 Info, Node040, Sending (Send) message (Callback ID=0xb1, Expected Reply=0x13) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=40): 0x01, 0x0f, 0x00, 0x13, 0x28, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0x1d, 0xff, 0x25, 0xb1, 0xff
2020-04-11 17:31:49.384 Error, Node040, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:31:49.384 Detail, Node040, Removing current message
2020-04-11 17:31:49.385 Detail, Node040, Notification: Notification - TimeOut
2020-04-11 17:31:49.391 Detail,
2020-04-11 17:31:49.391 Info, Node040, Sending (Send) message (Callback ID=0xb2, Expected Reply=0x04) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=40): 0x01, 0x0d, 0x00, 0x13, 0x28, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0xb2, 0x11
2020-04-11 17:31:50.391 Error, Node040, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:31:50.392 Detail, Node040, Removing current message
2020-04-11 17:31:50.392 Detail, Node040, Notification: Notification - TimeOut
2020-04-11 17:32:20.490 Detail, Node046, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-11 17:32:20.490 Detail, Node046, Queuing (Poll) SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xb3, 0x6a
2020-04-11 17:32:20.490 Info, Node046, Sending (Poll) message (Callback ID=0xb3, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=46): 0x01, 0x09, 0x00, 0x13, 0x2e, 0x02, 0x31, 0x04, 0x25, 0xb3, 0x6a
2020-04-11 17:32:21.491 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-11 17:32:21.491 Detail, Node046, Removing current message
2020-04-11 17:32:21.491 Detail, Node046, Notification: Notification - TimeOut
