Zwave plus device doesn't report as unavailable
I have a ZOOZ Z-Wave Plus 4-in-1 Sensor ZSE40 VER. 2.0 and I noticed that the temp and humidity readings hadn’t changed for several days. I tested the battery voltage with a multimeter which showed at 1.9 volts. I ordered a replacement battery and left the dead battery out. Homeassistant doesn’t report it as unavailable like it should ever since the battery level was too low or even after the battery was removed.
I use a Nortek GoControl HUSBZB-1 and the Home Assistant integrations for the hub.
What can I do to cause Home Assistant to report Zwave plus devices as unavailable when the battery is too low or removed?
I have never learned how to use mqtt. Would mqtt do a better job with Zwave plus devices reporting as unavailable when the battery is too low or removed?
