Zwave plus
I have Aeotec Z-stick Gen5 and a Fibaro Motion Sensor in the zwave network so far.
I have options.xml in the same folder as the zwcfg_xxx.xml (/config). I’m using docker.
After installing 0.41 I noticed that, for both, it is saying “is zwave plus - false”.
Questions:
  1. how can I enable zwave plus (both devices are capable)
  2. can a zwave device route zwave plus? (I will have multiple zwave light switches (powered) and multiple zwave plus motion sensors (battery only)
Thanks.
I have this on OZW_Log.txt:
2017-03-26 11:20:09.376 Always, OpenZwave Version 1.4.2481 Starting Up
2017-03-26 11:20:27.077 Info, Setting Up Provided Network Key for Secure Communications
2017-03-26 11:20:27.077 Info, mgr, Added driver for controller /dev/ttyACM0
2017-03-26 11:20:27.078 Info, Opening controller /dev/ttyACM0
2017-03-26 11:20:27.078 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2017-03-26 11:20:27.079 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2017-03-26 11:20:27.079 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-03-26 11:20:27.079 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-03-26 11:20:27.079 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-03-26 11:20:27.079 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-03-26 11:20:27.080 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
There should be no need to activate it, its something the device simply offers.
HA 0.41 also reports my Z-Stick to be “zwave plus: false” yet it is according to the technical specifications.
Other devices that are plus,are showing up as such though.
So how can I find out if the Fibaro is using Zwave Plus (encryption) or not?
From what I have read Z-Wave Plus only has a benefit if all devices in your network are plus.
Because it’s a mesh network non-plus devices cannot relay for plus-nodes (which will likely fall back to non-plus as a result?).
It could potentially still work if the node has a direct connection possible with the controller. The majority of my nodes are still non-plus, the plus one’s are “added securely” via OZWCP so I assume it uses Z-Wave plus with a direct connection to the controller (since the distance isn’t too far).
Yeah, I’m seeing it replace my Razberry Z-Wave+ controller as non-plus. Some of the devices were securely added, some weren’t, and a couple of them aren’t Z-Wave+ devices.
My own reading suggests that the presence of some non plus devices isn’t a problem.
I seem to have an issue here, too. All of my devices support z-wave plus according to the manufacturers. Also when starting hass.io, I get the massage:
Yet, hass.io says in dev-options, that my z-wave usb controller Me ZME_UZB1 is z-wave plus fase and also the same for some of my fibaro devices. So is there a way to check if secure communication is active and how can I enable it for all devices?
It’s normal for the controller to show up as non-Plus - that one you can ignore. If your other devices are reporting as non-Plus, then they are non-Plus.
As for secure communication - that is device specific and requires that:
  1. You’ve set up the network key
  2. Your device supports it
  3. You’ve used the Add Node Secure option to include it
That’s the whole point. Fibaro device is reported to be plus, I have a network key set in the config. I also added the device using “add node secure”.
Z-Wave plus doesn’t mean that encryption is in place - devices can still it, or not, regardless of whether they’re Plus or non-Plus. You need to check whether the device supports it before you try adding it. Once added you can check the attributes to see if it reports as being secured.
