Zwave polling killing battery
hi,
i have a zwave lock that is battery operated. Schlage BE469.
seems since i have enabled it in HA under zwave … the batteries seem to die very frequently.
any suggestions on how i can change polling frequency to prevent battery draining ?
thanks,
Polling should be 0 by default, but you can adjust it via the ZWave menu.
Select your Node (your Lock)
Select the Entity
Polling intensity will be an option. (Setting to 0 disables it)
thanks disabled all and fingers crossed.
@jayha Did this end up working for you?
nope… started to use re-chargeable batteries
