GuidoJ
(Guido)
May 6, 2024, 1:40pm
1
Hi, I’ve problems with my zwave devices after migrating vom HAOS to proxmox. Everyting else incl. zigbee is working fine. I’ve installted a new VM under proxmox and restored the latest Backup.
I’ve passed the USB zwave stick via deviceID and the stick is visible unter settings->system->hardware.
It’s a “Aeotec Z-Stick 7 | Z-Wave Plus V2 | ZWA010 | 700er Serie”.
the zwave devices are visible, but I can’t controll them. I’ve tried to add them as new devices, this does either not help.
Several Errors regarding zwave are in the log:
2024-05-06 12:37:06.957 ERROR (MainThread) [homeassistant.components.zwave_js] Unable to set value 13-37-0-targetValue: zwave_error: Z-Wave error 1405 - The node failed to decode the message. (ZW1405)
2024-05-06 12:37:06.958 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139884146382656] Unexpected exception
File “/usr/src/homeassistant/homeassistant/components/zwave_js/entity.py”, line 334, in _async_set_value
return await self.info.node.async_set_value
Can someone help me solve this problem?
Guido
Are you using Z-wave JS or Z-wave JS UI to communicate with your controller?
What is the device path configured in your chosen software?
Can you show all the z-wave log errors from a startup of the integration? You seem to have chosen specific errors above which is hard to understand out of context of the errors around it.
GuidoJ
(Guido)
May 6, 2024, 2:46pm
3
Here the hardware screenshot:
and the usb-Path in the z-wave-js
and the beginning of the logfile:
2024-05-06T12:59:17.341Z DRIVER version 12.5.5
2024-05-06T12:59:17.343Z DRIVER
2024-05-06T12:59:17.344Z DRIVER starting driver...
2024-05-06T12:59:17.344Z DRIVER opening serial port /dev/ttyUSB1
2024-05-06T12:59:17.388Z DRIVER serial port opened
2024-05-06T12:59:17.395Z SERIAL » 0x15 (1 bytes)
2024-05-06T12:59:17.818Z SERIAL « 0x012800a80001041f9f03eb001b95fb597de82995824b5a59f2e671a1bf5296df5 (42 bytes)
76a327886fbcb00a7db
2024-05-06T12:59:17.827Z DRIVER Dropping message because the driver is not ready to handle it yet.
2024-05-06T12:59:17.828Z SERIAL » [ACK] (0x06)
2024-05-06T12:59:18.404Z DRIVER loading configuration...
2024-05-06T12:59:18.420Z CONFIG Using external configuration dir /data/db
2024-05-06T12:59:18.420Z CONFIG version 12.5.5
2024-05-06T12:59:19.300Z DRIVER beginning interview...
2024-05-06T12:59:19.303Z DRIVER added request handler for AddNodeToNetwork (0x4a)...
1 registered
2024-05-06T12:59:19.304Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)...
1 registered
2024-05-06T12:59:19.305Z DRIVER added request handler for ReplaceFailedNode (0x63)...
1 registered
2024-05-06T12:59:19.305Z DRIVER added request handler for SerialAPIStarted (0x0a)...
1 registered
2024-05-06T12:59:19.307Z CNTRLR querying Serial API capabilities...
2024-05-06T12:59:19.539Z SERIAL » 0x01030007fb (5 bytes)
2024-05-06T12:59:19.541Z DRIVER » [REQ] [GetSerialApiCapabilities]
2024-05-06T12:59:19.548Z SERIAL « [ACK] (0x06)
2024-05-06T12:59:19.551Z SERIAL « 0x012b01070714000000040004f6873e88cf2bc04ffbd7fde09700008000808680b (45 bytes)
a0500700000ee7fc000000053
2024-05-06T12:59:19.553Z SERIAL » [ACK] (0x06)
2024-05-06T12:59:19.555Z DRIVER « [RES] [GetSerialApiCapabilities]
payload: 0x0714000000040004f6873e88cf2bc04ffbd7fde09700008000808680ba0500700
000ee7fc0000000
2024-05-06T12:59:19.562Z CNTRLR received API capabilities:
firmware version: 7.20
manufacturer ID: 0x00
product type: 0x04
product ID: 0x04
supported functions:
· GetSerialApiInitData (0x02)
· SetApplicationNodeInformation (0x03)
· GetControllerCapabilities (0x05)
· SetSerialApiTimeouts (0x06)
· GetSerialApiCapabilities (0x07)
· SoftReset (0x08)
· GetProtocolVersion (0x09)
· SerialAPIStarted (0x0a)
· SerialAPISetup (0x0b)
· SetRFReceiveMode (0x10)
· FUNC_ID_ZW_SEND_NODE_INFORMATION (0x12)
· SendData (0x13)
· SendDataMulticast (0x14)
· GetControllerVersion (0x15)
· SendDataAbort (0x16)
· FUNC_ID_ZW_GET_RANDOM (0x1c)
· GetControllerId (0x20)
· UNKNOWN_FUNC_MEMORY_GET_BYTE (0x21)
· UNKNOWN_FUNC_MEMORY_PUT_BYTE (0x22)
· UNKNOWN_FUNC_MEMORY_GET_BUFFER (0x23)
· UNKNOWN_FUNC_MEMORY_PUT_BUFFER (0x24)
· EnterBootloader (0x27)
· UNKNOWN_FUNC_UNKNOWN_0x28 (0x28)
· GetNVMId (0x29)
· ExtNVMReadLongBuffer (0x2a)
· ExtNVMReadLongByte (0x2c)
· NVMOperations (0x2e)
· undefined (0x37)
· undefined (0x38)
· UNKNOWN_FUNC_ClearNetworkStats (0x39)
· UNKNOWN_FUNC_GetNetworkStats (0x3a)
· GetBackgroundRSSI (0x3b)
· undefined (0x3c)
· UNKNOWN_FUNC_RemoveNodeIdFromNetwork (0x3f)
· GetNodeProtocolInfo (0x41)
· HardReset (0x42)
· FUNC_ID_ZW_REPLICATION_COMMAND_COMPLETE (0x44)
· FUNC_ID_ZW_REPLICATION_SEND_DATA (0x45)
· AssignReturnRoute (0x46)
· DeleteReturnRoute (0x47)
· RequestNodeNeighborUpdate (0x48)
· ApplicationUpdateRequest (0x49)
· AddNodeToNetwork (0x4a)
· RemoveNodeFromNetwork (0x4b)
· FUNC_ID_ZW_CONTROLLER_CHANGE (0x4d)
· AssignPriorityReturnRoute (0x4f)
· FUNC_ID_ZW_SET_LEARN_MODE (0x50)
· AssignSUCReturnRoute (0x51)
· FUNC_ID_ZW_REQUEST_NETWORK_UPDATE (0x53)
· SetSUCNodeId (0x54)
· DeleteSUCReturnRoute (0x55)
· GetSUCNodeId (0x56)
· UNKNOWN_FUNC_SEND_SUC_ID (0x57)
· AssignPrioritySUCReturnRoute (0x58)
· FUNC_ID_ZW_EXPLORE_REQUEST_INCLUSION (0x5e)
· undefined (0x5f)
· RequestNodeInfo (0x60)
· RemoveFailedNode (0x61)
· IsFailedNode (0x62)
· ReplaceFailedNode (0x63)
· undefined (0x65)
· undefined (0x68)
· GetRoutingInfo (0x80)
· UNKNOWN_FUNC_LOCK_ROUTE_RESPONSE (0x90)
· GetPriorityRoute (0x92)
· SetPriorityRoute (0x93)
· UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
· FUNC_ID_SERIAL_API_SLAVE_NODE_INFO (0xa0)
· FUNC_ID_ZW_SEND_SLAVE_NODE_INFO (0xa2)
· FUNC_ID_ZW_SET_SLAVE_LEARN_MODE (0xa4)
· FUNC_ID_ZW_GET_VIRTUAL_NODES (0xa5)
· FUNC_ID_ZW_IS_VIRTUAL_NODE (0xa6)
· BridgeApplicationCommand (0xa8)
· SendDataBridge (0xa9)
· SendDataMulticastBridge (0xab)
· UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
· UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
· UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
· UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
· UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
· UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
· undefined (0xd6)
· undefined (0xd7)
· undefined (0xd8)
· Shutdown (0xd9)
· GetLongRangeNodes (0xda)
· GetLongRangeChannel (0xdb)
· SetLongRangeChannel (0xdc)
· SetLongRangeShadowNodeIDs (0xdd)
· undefined (0xde)
· undefined (0xdf)
· undefined (0xe7)
· undefined (0xe8)
2024-05-06T12:59:19.563Z CNTRLR querying additional controller information...
2024-05-06T12:59:19.571Z SERIAL » 0x01030002fe (5 bytes)
2024-05-06T12:59:19.572Z DRIVER » [REQ] [GetSerialApiInitData]
2024-05-06T12:59:19.581Z SERIAL « [ACK] (0x06)
2024-05-06T12:59:19.583Z SERIAL « 0x012501020a081d791201000000000000000000000000000000000000000000000 (39 bytes)
00000000700ab
2024-05-06T12:59:19.584Z SERIAL » [ACK] (0x06)
2024-05-06T12:59:19.585Z DRIVER « [RES] [GetSerialApiInitData]
payload: 0x0a081d79120100000000000000000000000000000000000000000000000000000
700
2024-05-06T12:59:19.588Z CNTRLR received additional controller information:
Z-Wave API version: 1 (official)
Z-Wave chip type: EFR32ZG14 / ZGM130S
node type Controller
controller role: primary
controller is the SIS: true
controller supports timers: false
Z-Wave Classic nodes: 1, 4, 5, 6, 7, 10, 13, 17
2024-05-06T12:59:19.589Z CNTRLR querying version info...
2024-05-06T12:59:19.593Z SERIAL » 0x01030015e9 (5 bytes)
2024-05-06T12:59:19.594Z DRIVER » [REQ] [GetControllerVersion]
2024-05-06T12:59:19.600Z SERIAL « [ACK] (0x06)
2024-05-06T12:59:19.602Z SERIAL « 0x011001155a2d5761766520372e3230000795 (18 bytes)
2024-05-06T12:59:19.603Z SERIAL » [ACK] (0x06)
2024-05-06T12:59:19.604Z DRIVER « [RES] [GetControllerVersion]
payload: 0x5a2d5761766520372e32300007
2024-05-06T12:59:19.607Z CNTRLR received version info:
controller type: Bridge Controller
library version: Z-Wave 7.20
2024-05-06T12:59:19.607Z CNTRLR querying protocol version info...
2024-05-06T12:59:19.611Z SERIAL » 0x01030009f5 (5 bytes)
2024-05-06T12:59:19.611Z DRIVER » [REQ] [GetProtocolVersion]
2024-05-06T12:59:19.619Z SERIAL « [ACK] (0x06)
2024-05-06T12:59:19.620Z SERIAL « 0x011901090007140200d4303030303030303030303030303030302b (27 bytes)
2024-05-06T12:59:19.621Z SERIAL » [ACK] (0x06)
2024-05-06T12:59:19.622Z DRIVER « [RES] [GetProtocolVersion]
payload: 0x0007140200d430303030303030303030303030303030
2024-05-06T12:59:19.625Z CNTRLR received protocol version info:
protocol type: Z-Wave
protocol version: 7.20.2
appl. framework build no.: 212
git commit hash: 30303030303030303030303030303030
2024-05-06T12:59:19.625Z CNTRLR querying controller capabilities...
2024-05-06T12:59:19.628Z SERIAL » 0x01030005f9 (5 bytes)
2024-05-06T12:59:19.629Z DRIVER » [REQ] [GetControllerCapabilities]
2024-05-06T12:59:19.634Z SERIAL « [ACK] (0x06)
2024-05-06T12:59:19.635Z SERIAL « 0x010401051ce3 (6 bytes)
2024-05-06T12:59:19.636Z SERIAL » [ACK] (0x06)
2024-05-06T12:59:19.638Z DRIVER « [RES] [GetControllerCapabilities]
payload: 0x1c
2024-05-06T12:59:19.640Z CNTRLR received controller capabilities:
is the SUC: true
started this network: true
SIS is present: true
was real primary: true
2024-05-06T12:59:19.641Z CNTRLR querying serial API setup capabilities...
2024-05-06T12:59:19.644Z SERIAL » 0x0104000b01f1 (6 bytes)
2024-05-06T12:59:19.645Z DRIVER » [REQ] [SerialAPISetup]
command: GetSupportedCommands
payload: 0x01
2024-05-06T12:59:19.652Z SERIAL « [ACK] (0x06)
2024-05-06T12:59:19.653Z SERIAL « 0x0116010b01ff9f8007800000008000000000000000800085 (24 bytes)
2024-05-06T12:59:19.654Z SERIAL » [ACK] (0x06)
2024-05-06T12:59:19.655Z DRIVER « [RES] [SerialAPISetup]
payload: 0xff9f80078000000080000000000000008000
2024-05-06T12:59:19.658Z CNTRLR supported serial API setup commands:
· GetSupportedCommands
· SetTxStatusReport
· SetLongRangeMaximumTxPower
· SetPowerlevel
· GetLongRangeMaximumTxPower
· GetPowerlevel
· GetMaximumPayloadSize
· GetLongRangeMaximumPayloadSize
· SetPowerlevel16Bit
· GetPowerlevel16Bit
· GetRFRegion
· SetRFRegion
· SetNodeIDType
GuidoJ
(Guido)
May 6, 2024, 2:50pm
4
I’ve uploaded the complete file, it can be downloaded here:
Zwave_currend.log(Microsoft OneDrive )
These 2 things don’t match:
and
You have an extra “1” in the Z-wave JS configuration, unless you cut something off in posting the data which seems likely as the log show it is talking to the controller.
GuidoJ
(Guido)
May 6, 2024, 4:57pm
6
I think, that’s a problem of the horizontal scrolling
when I copy the ID from the Hardware Settings it’s the same as in the addOn config:
/dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_0a4e1302ef7ced119449d5f3fdf7b791-if00-port0
Reading through the logs, the controller is reporting no response to pings from nodes 7 and 17. They appear dead in the network.
Nodes 4 and 5 are consistently generating S2 security errors.
Assuming everything was working before the migration, how did the physical layout change (if at all)? Is the Proxmox hardware a new piece of hardware in the mix? Is the USB interface a USB2 or USB3 interface? If USB3, do you have the controller on an extension cable to avoid interference?
Was the Z-Wave-JS Add-on restored from the backup? Did you happen to save the security keys before migration? Are they the same?
It appears nodes 4 and 5 are the only S2 enabled devices. You could exclude and include them to see if the same errors occur.
Any logical accounting for why nodes 7 and 17 are now reporting dead? No physical changes in the mesh during the Proxmox migration?
GuidoJ
(Guido)
May 6, 2024, 6:06pm
8
i have restored to the same mini pc, only with proxmus installed.
The Zwave stick is in the same USB port as before.
The Z-Wave JS add-on was created by the restore, I didn’t save the security key. i confess i don’t even know where it is.
The zwave devices are all light switches, nothing has been changed on them.
Does it make sense to delete one and reinstall it as a test?
I believe the keys are in the Z-wave JS Add-on configuration. I can’t confirm as I use Z-wave JS UI.
It can’t hurt to exclude either nodes 4 or 5 as they don’t seem to be communicating at all.
In fact, I would probably move to Z-wave JS UI, it has much better troubleshooting tools, including a network map.
