Hi
After HA installation on VB i can not find Zwave it just shows openZwave?
Also, how can I find the name of my USB Zwave stick as it does not show HARDWARE on the settings page of UI?
You may not have exposed the USB stick to the VM.
You’ll want to go into your settings for the VM (while it’s not running) and click the USB
tab on the left panel. Then make sure the Enable USB Controller
checkbox is enabled, and then click the little USB plug with the green + sign to add your device.
After that, start your VM, and it should show the stick
I have it active just i do not know what name is it in HA.
Try running lsusb
on the vm shell. It may give you something to look for.
ok it will sound stupid but it asks me for a password once i put root it takes me to HA and linux commands are not working
What should i use to login ?
when i am using the username and pass i created when installing HA it said password incorrect ?
this is what i have after lsusb
Bus 001 Device 001: ID 1d6b:0001
Bus 001 Device 002: ID 0650:0200
Bus 001 Device 003: ID 80ee:0021
I suspect the second like of that output may be your z-wave stick. Do you have a /dev/ttyACM0
Maybe try posting the output of ls -al /dev/ttyACM*
and ls -al /dev/serial/by-path
2020-11-16 21:59:00.364 Always, OpenZwave Version 1.4.3469 Starting Up
2020-11-16 21:59:11.595 Info, Setting Up Provided Network Key for Secure Communications
2020-11-16 21:59:11.597 Info, mgr, Added driver for controller /dev/ttyS0
2020-11-16 21:59:11.602 Info, Opening controller /dev/ttyS0
2020-11-16 21:59:11.603 Info, Trying to open serial port /dev/ttyS0 (attempt 1)
2020-11-16 21:59:11.603 Error, ERROR: Failed to set serial port parameters
2020-11-16 21:59:11.603 Error, ERROR: Failed to open serial port /dev/ttyS0
2020-11-16 21:59:11.603 Warning, WARNING: Failed to init the controller (attempt 0)
ok i am stuck on the zwave USB
What am i doing wrong ?
After couple of restarts it added the port.
