Meanwhile I moved with my Raspberry to a different SD with the Raspbian image.
did the install and the update as well the RAZZBERRY update but still have the same issue
there is no /dev/ttyUSB…
pi@hassbian:~ $ ls /dev/ttyUSB*
ls: cannot access ‘/dev/ttyUSB*’: No such file or directory
But a AMA0
pi@hassbian:~ $ ls /dev/ttyA*
/dev/ttyAMA0
belong to group tty
pi@hassbian:~ $ ls -l /dev/ttyAMA0
crw--w---- 1 root tty 204, 64 Dec 14 20:59 /dev/ttyAMA0
I added:
zwave:
usb_path: /dev/ttyAMA0
to my virgin configuration.yaml
HomeAssistant is still throwing and error at startup:
2017-12-14 20:59:52 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
File "/srv/homeassistant/lib/python3.5/site-packages/openzwave/option.py", line 75, in __init__
raise ZWaveException(u"Can't write to device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: "Zwave Generic Exception : Can't write to device /dev/ttyAMA0 : ['NoneType: None\\n']"
But now the group is tty and there is
pi@hassbian:~ $ grep 'tty' /etc/group
tty:x:5:
and I asume to run it as homeassistant
pi@hassbian:~ $ ps axu | egrep "homeassist|hass"
avahi 353 0.0 0.2 6532 2760 ? Ss 20:59 0:00 avahi-daemon: running [hassbian.local]
homeass+ 524 5.5 5.8 379452 55460 ? Ssl 20:59 0:40 /srv/homeassistant/bin/python3 /srv/homeassistant/bin/hass
pi 872 0.0 0.0 4372 564 pts/0 S+ 21:12 0:00 grep -E --color=auto homeassist|hass
pi@hassbian:~ $
