Hello i had i working ha 0.41 installed with allinone, with razberry 2 card on rpi2.
i did an upgrade to 0.47 and zwave crashed. on ozwcp i could initialize razberry ans see all devices.
i did a fresh install with allinone but again zwave is not working and also there is no ozwcp
error log
2017-06-30 17:26:59 WARNING (Thread-1) [homeassistant.components.zwave] ZWave entity_ids will soon be changing. To opt in to new entity_ids now, set new_entity_ids: true
under zwave in your configuration.yaml. See the following blog post for details: https://home-assistant.io/blog/2017/06/15/zwave-entity-ids/
2017-06-30 17:26:59 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
File “/home/homeassistant/.homeassistant/deps/openzwave/option.py”, line 75, in init
raise ZWaveException(u"Can’t write to device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception
return list(_format_exception_iter(etype, value, tb, limit, chain))
File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter
for value, tb in values:
File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain
context = exc.context
AttributeError: ‘NoneType’ object has no attribute ‘context’
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/setup.py”, line 190, in _async_setup_component
component.setup, hass, processed_config)
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/init.py”, line 268, in setup
config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
File “/home/homeassistant/.homeassistant/deps/openzwave/option.py”, line 81, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /dev/ttyAMA0 : [‘Traceback (most recent call last):\n’, ’ File “/home/homeassistant/.homeassistant/deps/openzwave/option.py”, line 75, in init\n raise ZWaveException(u"Can\‘t write to device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception\n return list(_format_exception_iter(etype, value, tb, limit, chain))\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter\n for value, tb in values:\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain\n context = exc.context\n’, “AttributeError: ‘NoneType’ object has no attribute ‘context’\n”]’
can anyone help please?
