After several searches on this forum and Google, I can’t find a solution to my case.
I would like to configure my ZWAVE Aeotec LED Bulb.
The value i would like to send is
- 0x01 (Size 1)
- 0x01 (Size 1)
- 0x00000032 (Size 4)
- 0x01 (Size 1)
- 0x14 (Size 1)
- 0x01 (Size 1)
- 0x0A8C (Size 2)
- 0x1964 (Size 2)
I understand i need to translate 0x19640A8C011401000000320101 into a DEC = 2011665314248134872182601941249.
But when I test zwave.set_config_parameter I have the message “Failed to call service zwave/set_config_parameter. Python int too large to convert to C unsigned long”.
Is it possible to send RAW data for big number ? Or i need to split in multiple send (how?) ?
Thnaks in advance for your help.
Link of the Spec, look chapter 4.5
piece of my ZWCFG file
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
<Instance index="1" />
<Value type="list" genre="config" instance="1" index="1" label="Profile Buttons 1 & 3" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2>
<Help>This parameter configures the behavior of the buttons 1 and 3 when the product is in "Gateway Centric Mode"</Help>
<Item label="Scene Mode" value="0" />
<Item label="Mono Mode" value="1" />
<Item label="Duo Mode" value="2" />
</Value>
<Value type="list" genre="config" instance="1" index="2" label="Profile Buttons 2 & 4" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2>
<Help>This parameter configures the behavior of the buttons 2 and 4 when the product is in "Gateway Centric Mode"</Help>
</Value>
<Value type="list" genre="config" instance="1" index="3" label="Scene Type" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" si>
<Help>This parameter configures the type of command sent when the product is in "Gateway Centric Mode", with buttons profile configuration set in "Scene Behavior".</>
<Item label="Central Scene" value="0" />
<Item label="Scene Activation" value="1" />
</Value>
<Value type="list" genre="config" instance="1" index="4" label="Action Button 1 Mono" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vin>
<Help>When button are set in Mono Button mode they can have 3 different behaviors : 1: They can directly control other nodes with Basic and multi-level command class 2: Send Switch All >
<Item label="Control Group 2" value="0" />
<Item label="All Switch ON" value="1" />
<Item label="All Switch OFF" value="2" />
</Value>
<Value type="list" genre="config" instance="1" index="5" label="Action Button 2 Mono" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vin>
<Item label="Control Group 3" value="0" />
</Value>
<Value type="list" genre="config" instance="1" index="6" label="Action Button 3 Mono" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vin>
<Item label="Control Group 4" value="0" />
</Value>
<Value type="list" genre="config" instance="1" index="7" label="Action Button 4 Mono" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vin>
<Item label="Control Group 5" value="0" />
</Value>
<Value type="list" genre="config" instance="1" index="8" label="Led Management" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="3" vindex="3>
<Item label="Led OFF" value="0" />
<Item label="Led Blink on button action" value="1" />
<Item label="Led Blink on transmission result" value="2" />
<Item label="Led Blink on button action and transmission result" value="3" />
</Value>
</CommandClass>
