Greetings,
I have a very strange issue I hope its not a know defect. I recently upgraded from 0.112.4 to 0.114.4. In my config I have a script that turns lights on for a set time and i have a Homeseer paddle switch that has 7 LED’s on the side. As any script executes I set a led to a color while the script or automation is running.
The current issue is that the script I have sets a parameter to blue and 5 mins later it should switch the led off.
I am using the following to set the LED to blue:
Call Service, zwave.set_paramater:
node_id: 27
parameter: 27
value: Blue
I am using the following to attempt to turn the LED off:
Call Service, zwave.set_parameter
node_id: 27
parameter: 27
value: 'Off'
Troubleshooting I have done:
I confirmed with the zwcfg file that Off is a valid state.
I have created a script with just the call service set parameter. If I call it manually it turns the LED off. If i call the script “LED7_off” with home_assistant.on (to trigger the script) in the main script the LED stays on and blue. its as if the second set_parameter is not being sent.
Im at a loss for what i am doing wrong it is the only casualty of the 112 to 114 upgrade.
Thanks in advance of any assistance or ideas you may have to remediate this.
