Its my first post, a problem drove me here. After a rapsbian upgrade to Buster and a restart the Z-Wave stick does not work. I suspect something with a driver. But i cant find many details on this point.
Home assistant cant find ttyACM0. Currently there is no ttyACM*
Searching for the problem:
the stick shows up in the usb listing (lsusb) Bus 001 Device 004: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
On the driver messages (dmesg)
[ 2.271437] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[ 2.404691] usb 1-1.4: New USB device found, idVendor=0658, idProduct=0200
[ 2.407398] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.781436] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
Reading other post with logs in it, I would expect another line. [ 2.4******* ] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
Can any one confirm that the missing line is a symptom of the problem, And/Or tell me whats wrong?
If you use a Pi4, try to use the stick via a simple USB 2.0 hub. There is a suspected USB specs issue with the Aeon stick which causes a problem with Pi 4 new USB controller.
If it’s not a Pi4, then do you have anything else connected to any other USB port? Sometimes they are conflicting and only the faster device gets recognized upon boot.
I looked at cdc_acm, its a kernel module. Thats not giving the suspected message. The command lsmod shows an empty list.
looking at the boot log showed: (cat /var/log/syslog)
Aug 4 12:09:07 Groot systemd-udevd[140]: could not open moddep file '/lib/modules/4.14.98-v7+/modules.dep.bin'
Aug 4 12:09:07 Groot systemd[1]: Found device /dev/serial1.
Aug 4 12:09:07 Groot systemd-udevd[137]: could not open moddep file '/lib/modules/4.14.98-v7+/modules.dep.bin'
Looking at /lib/modules/* I see 4.19.57+ and 4.19.57-v7+.
The kernel got updated, upgrading to buster. So the /lib/modules/** got replaced to there new version.
Upgrading the kernel uses the /boot folder. aka the “boot” partition. Using an hdd to run rasbian i had the following following partitions: (spot the disaster)
sd - boot (used to boot)
hdd - boot (mouted as /boot)
hdd - rootfs (mounded as / , contains /lib/modules)
knowing everything above, the solution: Fixing /boot at fstab to the correct partition, upgrading to the correct kernel matching /lib/modules.
