Hello!
I’ve set up my Orange pi with the latest Armbian, installed Python3.6 and home assistant in venv. I’ve also linked /dev/ttyACM0
to /dev/zwave
. I’ve also made sure that homeassistant
is member of dialout
. The first time i startet hass
manually in venv, I saw that the openzwave stuff got installed. It also showed up in my browser after it was finished, but with no name on the stick, that’s ok. So i stopped it, and started it again, and then it shows with it’s name.
But when i start it as a service
It’s not showing. It just says: Invalid config
Here is a screenshot when i start it manually in venv, with these commands:
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/bin/activate
hass
Screenshot:
So, it looks promosing, only if I could get it started running as a service as well…
Can anyone give me a hint of what I should look for here?
