I’ve just finished migrating my Hass setup from Zwave-JS to Zwave-JS UI (HACS), one of the reason to make this switch is that somehow my Zwave network was dead and i was unable to heal it.
My Zwave setup is simple:
- 1x Zwave stick ZOOS ZST10
- 3x Yale Smartslocks
- 1x Linear garage door opener.
Zwave JS UI shows it as a star configuration, where the stick is the center.
For the migration and reconnecting the devices, i moved my RPI with HA outside the normal server box; it was about 1ft higher than normal. Once completed, I moved the RPI back to normal position.
At this point, one of my Yale Zwave nodes went dead. Its 1 floor up, about 10ft away through drywood walls.
I am expecting range problems so thinking of changing transmit power.
ZWaveJS UI allows to play with the ZOOS’ controller settings:
- Normal power level: current value = 0
- Measured Output Power at 0 dbm : current value = 6.3
Any recommendations on next steps?
