I can’t get my Aeotec Z-Wave Stick to run on the latest DSM (6.2.3-25426) and HA (0.110.3) , after it ran really well for at least a year.
I read those two manuals and though I implemented it correctly:
https://www.home-assistant.io/docs/installation/docker/ and
https://philhawthorne.com/installing-home-assistant-io-on-a-synology-diskstation-nas/
Here is what I got:
jhein@xxx:~$ ls -la /dev/ttyACM0
crw------- 1 root root 166, 0 May 28 19:15 /dev/ttyACM0
root@xxx:~# lsusb -iUc
|__1-1 0658:0200:0000 02 2.00 12MBit/s 100mA 2IFs ( ffffffd1ffffffb2ffffffdbffffffad)
1-1:1.0 (IF) 02:02:01 1EP () cdc_acm tty/ttyACM0
1-1:1.1 (IF) 0a:00:00 2EPs () cdc_acm
|__1-2 051d:0003:0106 00 2.00 12MBit/s 2mA 1IF (American Power Conversion Smart-UPS 1500 FW:UPS 09.3 / ID=18 AS1802155151 )
1-2:1.0 (IF) 03:00:00 2EPs () usbfs
|__1-3 f400:f400:0100 00 2.00 480MBit/s 200mA 1IF (Synology DiskStation 6500827C00DA5A83)
1-3:1.0 (IF) 08:06:50 2EPs () usb-storage host9 (synoboot)
Command to create the container (multiple lines for readability):
sudo docker run --name="13-home-assistant-zwave"
-v /volume1/docker/home-assistant/slave-zwave:/config
--device /dev/ttyACM0 -e TZ=Europe/Berlin --net=host
--privileged -itd homeassistant/home-assistant:stable`
ZWave Config:
zwave:
usb_path: /dev/ttyACM0
polling_interval: 60000
What I get is:
2020-05-29 05:17:29.166 Always, OpenZwave Version 1.4.3469 Starting Up
2020-05-29 05:17:29.303 Info, Setting Up Provided Network Key for Secure Communications
2020-05-29 05:17:29.303 Info, mgr, Added driver for controller /dev/ttyACM0
2020-05-29 05:17:29.303 Info, Opening controller /dev/ttyACM0
2020-05-29 05:17:29.303 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2020-05-29 05:17:29.303 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2020-05-29 05:17:29.303 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-05-29 05:17:29.304 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-05-29 05:17:29.304 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-05-29 05:17:29.304 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-05-29 05:17:29.304 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-05-29 05:17:29.304 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-05-29 05:17:30.304 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-29 05:17:30.304 Detail, contrlr, Removing current message
2020-05-29 05:17:30.304 Detail, contrlr, Notification: Notification - TimeOut
2020-05-29 05:17:30.306 Detail,
2020-05-29 05:17:30.307 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-05-29 05:17:31.307 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-29 05:17:31.307 Detail, contrlr, Removing current message
2020-05-29 05:17:31.307 Detail, contrlr, Notification: Notification - TimeOut
2020-05-29 05:17:31.308 Detail,
2020-05-29 05:17:31.308 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-05-29 05:17:32.308 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-29 05:17:32.308 Detail, contrlr, Removing current message
2020-05-29 05:17:32.308 Detail, contrlr, Notification: Notification - TimeOut
2020-05-29 05:17:32.309 Detail,
2020-05-29 05:17:32.309 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-05-29 05:17:33.309 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-29 05:17:33.309 Detail, contrlr, Removing current message
2020-05-29 05:17:33.309 Detail, contrlr, Notification: Notification - TimeOut
2020-05-29 05:17:33.310 Detail,
2020-05-29 05:17:33.310 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-05-29 05:17:34.310 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-29 05:17:34.310 Detail, contrlr, Removing current message
2020-05-29 05:17:34.310 Detail, contrlr, Notification: Notification - TimeOut
The device is passed through to the container. I did an ls -l /dev/ttyACM0 inside the container.
Any help would be highly appreciated.
Thank you,
Julian
