My Zwave stopped working with a recent upgrade. Cannot connect anymore. Here are the messages from zwave2mqtt.
[8:35 AM]
2021-11-07 08:32:48.930 WARN STORE: scenes.json not found 2021-11-07 08:32:48.947 INFO APP: Listening on port 44920 host 0.0.0.0 protocol HTTP 2021-11-07 08:32:48.972 INFO MQTT: MQTT is disabled 2021-11-07 08:32:48.982 INFO ZWAVE: Connecting to /dev/ttyACM0 2021-11-07 08:32:58.026 INFO ZWAVE: Controller status: Driver: Failed to open the serial port: Error: No such file or directory, cannot open /dev/ttyACM0 (ZW0100) 2021-11-07 08:32:58.027 WARN ZWAVE: Retry connection in 3 seconds… 2021-11-07 08:33:01.032 INFO ZWAVE: Connecting to /dev/ttyACM0
This fixed it, I had to stop VM then reinsert stick.
Hi.
The issue is related to the soft restart inside zwavejs2mqtt. I disabled it, removed and inserted the z-wave stick again and rebooted home assistant, and I was up and running again. Thanks for the help
I feel like I am having a similar issue. I rebooted the VM a few times no dice. I will shutdown pull zwave stick and reinsert it. Home assistant is currently not even seeing ttyACM0 anymore.
Edit: I just followed your instructions and that worked great! Thank you! I was pulling my hair out!
I’ve got the same problem here and haven’t found the option to disable soft-reset yet. Can anyone help me?
I think the option can be found in de webinterface of ZwaveJS, but that interface isn’t running when the service isn’t starting all the way.
