I’m a long time openhab user and am trying out HA after my host laptop bricked. I’ve got my zwave stick (AEON) plugged into Pi-4 and figured out which /dev address it is on. Starting the network, it just spins. Below is the only log output I get. The documentation mentions setting up the ports in raspi-config, but this isn’t available via ssh. I’m a little fuzzy on whether HA OS completely supplants raspian, but suspect this is the case. Any help appreciated.
2021-01-27 14:49:38.654 Always, OpenZwave Version 1.4.3469 Starting Up
2021-01-27 14:49:40.655 Info, Setting Up Provided Network Key for Secure Communications
2021-01-27 14:49:40.655 Info, mgr, Added driver for controller /dev/ttyAMA0
2021-01-27 14:49:40.655 Info, Opening controller /dev/ttyAMA0
2021-01-27 14:49:40.656 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2021-01-27 14:49:40.656 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2021-01-27 14:49:40.657 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-27 14:49:40.657 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2021-01-27 14:49:40.657 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2021-01-27 14:49:40.657 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2021-01-27 14:49:40.657 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2021-01-27 14:49:40.657 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-27 14:49:40.657 Detail, contrlr, Notification: DriverFailed
