ZWave suddenly stop responding with The controller is jammed and Failed to execute controller command
After a long time (more than a year) of stability, Zwave stopped working.
Every time I reconfigure the server via the UI (to try to get it to work again), it works once or twice, then drops dead.
I have about 10 devices of Aeontec mini dimmers and a few sensors, which have worked very well for a long time.
Logs here (info):
Debug logs (below the info logs ) have a shitload of information about power consumption coming several times a second.
I tried to increase the reporting time the configuration has (3 second) but cant (getting An error occurred.
zwave_error: Z-Wave error 202 - Failed to send the command after 5 attempts (ZW0202))
On recent versions of HA, ZWave integ, and anything else HA offers.
Subscribed to Z-Wave JS log messages…
2024-04-25T16:09:24.751Z CNTRLR   The controller is no longer jammed
2024-04-25T16:09:34.048Z CNTRLR   The controller is jammed
2024-04-25T16:09:38.117Z CNTRLR   The controller is no longer jammed
2024-04-25T16:09:38.136Z CNTRLR   The controller is jammed
2024-04-25T16:09:42.199Z CNTRLR   The controller is no longer jammed
2024-04-25T16:10:33.540Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2024-04-25T17:12:42.321Z CNTRLR   The controller is jammed
2024-04-25T17:12:46.385Z CNTRLR   The controller is no longer jammed
2024-04-25T17:12:46.404Z CNTRLR   The controller is jammed
2024-04-25T17:12:50.466Z CNTRLR   The controller is no longer jammed
2024-04-25T17:17:40.525Z SERIAL « 0x011c00a800000100170e320221740000000000000000000000c8007f7ffe      (30 bytes)
2024-04-25T17:17:40.526Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:40.528Z CNTRLR   [Node 023] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2024-04-25T17:17:40.528Z CNTRLR   [Node 023] [~] [Meter] value[66049]: 0 => 0                       [Endpoint 0]
2024-04-25T17:17:40.529Z DRIVER « [Node 023] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -56 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      0
                                      time delta: 0 seconds
2024-04-25T17:17:40.640Z SERIAL « 0x011c00a800000100170e3202a1640000000000000000000000c4007f7f62      (30 bytes)
2024-04-25T17:17:40.640Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:40.641Z CNTRLR   [Node 023] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2024-04-25T17:17:40.642Z CNTRLR   [Node 023] [~] [Meter] value[66561]: 0 => 0                       [Endpoint 0]
2024-04-25T17:17:40.642Z DRIVER « [Node 023] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -60 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      0
2024-04-25T17:17:40.753Z SERIAL « 0x011c00a800000100170e3202a1640000000000000000000000c4007f7f62      (30 bytes)
2024-04-25T17:17:40.754Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:40.755Z CNTRLR   [Node 023] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2024-04-25T17:17:40.755Z CNTRLR   [Node 023] [~] [Meter] value[66561]: 0 => 0                       [Endpoint 0]
2024-04-25T17:17:40.756Z DRIVER « [Node 023] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -60 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      0
2024-04-25T17:17:40.792Z DRIVER   all queues busy
2024-04-25T17:17:40.794Z SERIAL » 0x0103003bc7                                                         (5 bytes)
2024-04-25T17:17:40.794Z DRIVER » [REQ] [GetBackgroundRSSI]
2024-04-25T17:17:40.799Z SERIAL « [ACK]        (0x06)
2024-04-25T17:17:40.799Z SERIAL « 0x0107013bb5b2b27f08                                                 (9 bytes)
2024-04-25T17:17:40.800Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:40.801Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -75 dBm
                                    channel 1: -78 dBm
                                    channel 2: -78 dBm
                                    channel 3: N/A
2024-04-25T17:17:40.803Z DRIVER   all queues idle
2024-04-25T17:17:40.936Z SERIAL « 0x011c00a800000100170e3202a1640000000000000000000000c3007f7f65      (30 bytes)
2024-04-25T17:17:40.937Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:40.938Z CNTRLR   [Node 023] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2024-04-25T17:17:40.939Z CNTRLR   [Node 023] [~] [Meter] value[66561]: 0 => 0                       [Endpoint 0]
2024-04-25T17:17:40.939Z DRIVER « [Node 023] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -61 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      0
2024-04-25T17:17:41.082Z SERIAL « 0x011c00a8000001000c0e3202a1640000000000000000000000c6007f7f7b      (30 bytes)
2024-04-25T17:17:41.083Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:41.084Z CNTRLR   [Node 012] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2024-04-25T17:17:41.084Z CNTRLR   [Node 012] [~] [Meter] value[66561]: 0 => 0                       [Endpoint 0]
2024-04-25T17:17:41.085Z DRIVER « [Node 012] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -58 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      0
2024-04-25T17:17:41.247Z SERIAL « 0x011c00a8000001000c0e3202a16c0000000000000000000000c7007f7f72      (30 bytes)
2024-04-25T17:17:41.248Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:41.249Z CNTRLR   [Node 012] [Meter] value[66817]: metadata updated                 [Endpoint 0]
2024-04-25T17:17:41.249Z CNTRLR   [Node 012] [~] [Meter] value[66817]: 0 => 0                       [Endpoint 0]
2024-04-25T17:17:41.250Z DRIVER « [Node 012] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -57 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      A
                                      rate type:  Consumed
                                      value:      0
2024-04-25T17:17:41.287Z SERIAL « 0x011c00a800000100170e3202a1640000000000000000000000c8007f7f6e      (30 bytes)
2024-04-25T17:17:41.288Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:41.289Z CNTRLR   [Node 023] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2024-04-25T17:17:41.289Z CNTRLR   [Node 023] [~] [Meter] value[66561]: 0 => 0                       [Endpoint 0]
2024-04-25T17:17:41.290Z DRIVER « [Node 023] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -56 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      0
2024-04-25T17:17:41.577Z SERIAL « 0x011c00a8000001000c0e3202a16c0000000000000000000000c4007f7f71      (30 bytes)
2024-04-25T17:17:41.578Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:41.579Z CNTRLR   [Node 012] [Meter] value[66817]: metadata updated                 [Endpoint 0]
2024-04-25T17:17:41.580Z CNTRLR   [Node 012] [~] [Meter] value[66817]: 0 => 0                       [Endpoint 0]
2024-04-25T17:17:41.581Z DRIVER « [Node 012] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -60 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      A
                                      rate type:  Consumed
                                      value:      0
2024-04-25T17:17:41.608Z SERIAL « 0x011c00a8000001000c0e320221740000000000000000000000c6007f7feb      (30 bytes)
2024-04-25T17:17:41.609Z SERIAL » [ACK]        (0x06)
2024-04-25T17:17:41.611Z CNTRLR   [Node 012] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2024-04-25T17:17:41.612Z CNTRLR   [Node 012] [~] [Meter] value[66049]: 0 => 0                       [Endpoint 0]
2024-04-25T17:17:41.612Z DRIVER « [Node 012] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -58 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      0
Have you tried to power cycle your HA box ?
thanks @enduser. Yes, I have. the box and the stick.
