Zwave swimming pool temperature sensor
I bought some Fibaro Universal Sensors and started with building a water-proof temperature sensor for my swimming pool:
Now waiting for the other temp sensors to arrive so I can complete the other two universal sensors…
I would like to have not only the temperature monitored but also the pH and chlorine levels.
Do you have a solution for this ?
No, tried also to find sensors for that. I use Lovibond Scuba II manually. I write the readings to spreadsheet so I can predict when to add more chlorine.
I have found this sensor: X200pH.
Have to check those later. The problem will be how to get that reading to Zwave/Zigbee. Greatest benefit of Fibaro Universal Sensor was it already supports 1-wire temp sensor so no coding or designing custom boards needed.
How do you get the entities of Universal Binary Sensor for temperature data?
I can only find entities for the two sensors.
waterproof version of dsb1820 is available
regular sensor
https://www.amazon.com/dp/B0184WW06W/ref=asc_df_B0184WW06W5214367/?tag=hyprod-20&creative=395033&creativeASIN=B0184WW06W&linkCode=df0&hvadid=198072959016&hvpos=1o1&hvnetw=g&hvrand=1638015941467841250&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028214&hvtargid=pla-319313556210
I have attached the sensors. I expected that the temperature would apear as entities as it does with the FGK-10x door window sensor.
