I’m try to use a zwave controller and I’ve some problem. How can I test if the devices is initializable from openzawave ?
https://home-assistant.io/docs/installation/raspberry-pi-all-in-one/
Scroll down to openzwave instructions, follow them.
Then select ‘add device’ from the controller menu.
Instructions are definitely up to date, literally used them myself two hours ago to reset my z-wave netweork and start again.
Hope you get it all working.
Now I’ve ozw-control-panel but I see error in log and I don’t responde http://your_raspberry_pi_ip:8123
In the log of installation there are no errors
Your post doesn’t really explain what’s going on your end, can you expand a little please?
The process should be:
- Stop home assistant
- Start ozwcp
- Access ozwcp on http://your.ip.address:8888
- Make your changes
- Save your changes
- Quit ozwcp
- Start home assistant
- Access home assistant on http://your.ip.address:8123
- Profit
