Zwave timeout
I have a zooz switch. When I try to flip it on lovelace I get this in the logs. I don’t even know where to start with troubleshooting. Does anyone have any guidance?
2020-07-19 14:11:28.443 Info, Node005, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2020-07-19 14:11:28.443 Info, Node005, SwitchBinary::Set - Setting node 5 to On
2020-07-19 14:11:28.443 Detail, Node005, Queuing (Send) SwitchBinaryCmd_Set (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x25, 0x01, 0xff, 0x25, 0x3f, 0x21
2020-07-19 14:11:28.443 Detail, Node005, Queuing (Send) SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x40, 0xa0
2020-07-19 14:11:28.444 Detail,
2020-07-19 14:11:28.444 Info, Node005, Sending (Send) message (Callback ID=0x3f, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x25, 0x01, 0xff, 0x25, 0x3f, 0x21
2020-07-19 14:11:29.444 Error, Node005, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-07-19 14:11:29.444 Detail, Node005, Removing current message
2020-07-19 14:11:29.444 Detail, Node005, Notification: Notification - TimeOut
I’ve seen that before, and usually exclude/reinclude does the trick. That happens to me more often if the device is located where it has a weak signal… or something else in HA buggers the include process (low resources etc). Not guaranteed, but it is easy to try reincluding closer to the stick, and see if it works.
If this doesn’t work, I would also try power cycling the device, as I have occasionally had devices crash on me which also causes them to not respond to commands in this way.
