I am having all sorts of problems with my Z-Wave setup to the extent that I have just done a full reset vi ozwcp to try and resolve the issues.
- I am running latest HA in a docker container running on an Ubuntu esxi VM
- I have an Aeotec ZStick Gen 5 controller shared with the VM as /dev/ttyACM0 and then shared to the docker container
- When I originally set this up - way back everything worked brilliantly, now not so much
- at least 50% of the time I am getting errors in the ZWave logs about expected responses not being received:
2017-08-30 09:45:07.478 Info, Node002, Sending (WakeUp) message (Callback ID=0x27, Expected Reply=0x13) - WakeUpCmd_NoMoreInformation (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x84, 0x08, 0x25, 0x27, 0x6b2017-08-30 09:45:08.478 Error, Node002, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-08-30 09:45:08.478 Detail, Node002, Removing current message
2017-08-30 09:45:08.478 Detail, Node002, Notification: Notification - TimeOut
2017-08-30 09:45:44.971 Detail, Queuing (Controller) Remove Device
2017-08-30 09:45:44.971 Info, Remove Device
2017-08-30 09:45:44.971 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x28, 0x18
2017-08-30 09:45:44.971 Detail, Notification: ControllerCommand - Starting
2017-08-30 09:45:44.971 Info, contrlr, Sending (Command) message (Callback ID=0x28, Expected Reply=0x4b) - ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x28, 0x18
2017-08-30 09:45:45.971 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)**
2017-08-30 09:45:45.971 Detail, contrlr, Removing current message
2017-08-30 09:45:45.971 Detail, contrlr, Notification: Notification - TimeOut
2017-08-30 09:45:45.971 Detail, Notification: ControllerCommand - Error - Failed
- If I retry the command it will sometimes work sometimes not. I just ran an adddevice which sort of worked but then failed when it tried to do further discovery on the device just added.
Is there some timeout or retry value that I am missing?
