Each time I want to do something with Zwave (Add a device, remove, heal) I must go to Settings, Integrations, then go down the list till I find the Zwave integration.
Is there a way to add these tools directly in a card in the Dashboard (Overview) ?
You could create a card which links to the URL of the ZWave settings
Would you mind explaining how to do that ?
I was not aware that one could add a url in a card.
One way to do it is using the Markdown Card and simply put the URL in it like this:
[Open ZWave Config(https://192.168.0.100/config/devices/dashboard?xxxx)
Where the address in the brackets is the URL you can copy from your browser when you go to the ZWave config screen.
Thanks so much. I am a recent HA convert and not all that technical. I am not yet familiar with Lovelace and hesitant with Yaml. I need to learn more and will keep your suggestion. Thanks again.
