I installed HASS on an RPI3 with Raspbian light using the AIO script. When trying to initialize the Open-Zwave usb stick I get:
2016-12-01 20:17:12.204 Always, OpenZwave Version 1.4.2274 Starting Up
2016-12-01 20:17:35.206 Info, Setting Up Provided Network Key for Secure Communications
2016-12-01 20:17:35.207 Warning, Failed - Network Key Not Set
2016-12-01 20:17:35.207 Info, mgr, Added driver for controller /dev/ttyAMA0
2016-12-01 20:17:35.207 Info, Opening controller /dev/ttyAMA0
2016-12-01 20:17:35.208 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2016-12-01 20:17:35.209 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2016-12-01 20:17:35.210 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2016-12-01 20:17:35.210 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2016-12-01 20:17:35.210 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2016-12-01 20:17:35.210 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2016-12-01 20:17:35.211 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2016-12-01 20:17:35.212 Detail,
2016-12-01 20:17:35.212 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2016-12-01 20:17:36.212 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2016-12-01 20:17:36.213 Detail, contrlr, Removing current message
2016-12-01 20:17:36.223 Detail, contrlr, Notification: Notification - TimeOut
2016-12-01 20:17:36.223 Info, Notification: Notification home 00000000 node 255 Timeout
What am I doing wrong ? The Open-zwave stick is working fine on my Ubuntu machine.
