I upgraded to .47 and received the below error message regarding zwave.
I downgraded to .46.1 and I"m still receiving the same error message. I even downgraded to .46 and I"m still getting the same error message.
I’m also seeing the below error. I’m not sure if this means there’s an issue with the component itself or my configuration?
File “/usr/src/app/homeassistant/setup.py”, line 190, in _async_setup_component
component.setup, hass, processed_config)
File “/usr/local/lib/python3.6/asyncio/futures.py”, line 331, in iter
yield self # This tells Task to wait for completion.
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 244, in _wakeup
future.result()
File “/usr/local/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self._exception
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/src/app/homeassistant/components/zwave/init.py”, line 268, in setup
config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
File “/usr/local/lib/python3.6/site-packages/openzwave/option.py”, line 81, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : [‘Traceback (most recent call last):\n’, ’ File “/usr/local/lib/python3.6/site-packages/openzwave/option.py”, line 78, in init\n raise ZWaveException(u"Can\‘t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n’, ‘openzwave.object.ZWaveException: “Zwave Generic Exception : Can\'t find device /dev/ttyACM0 : [\‘NoneType: None\\\\n\’]”\n’]’
In case someone else has this issue or I forget when launching the Docker container you need to select with high priority.
