I am in the process of moving over to zwave2mqtt. I have a couple of the go control GC-tbz48 thermostats. When I add them to zwave2mqtt they show up as a Thermostat HVAC device and the correct description. However it doesn’t come into HA as a thermostat. I get 4 sensors that show up in the HA Devices section:
sensor_scene_state
sensor_scene_state_1
sensor_battyer_level
Sensor_temperature_air
For the life of me I can’t get the HA devices added. In the zwave2mqtt github it shows an example template for this, I added that to the customDevice.json file (Running in docker) and the log says it was added, but if no matter what I do I can’t get this to show up as a thermostat in HA.
so I am struggling with the customDevice.js or .json. If I pass it directly from the website I get an error that / is not supported, and that makes sense since json doesn’t support comments. Do you mind sharing your customDevice.js file? or the section you pasted in for this thermostat?
