I use zwave2mqtt, I want to poll some node manually, so I send command like openzwave/1/command/requestnodedynamic or others, but I don’t have anything append, no trace in logs. openzwave is the prefix set in settings.
I have not done this before, but I think I have about figured this out for you.
The mqtt format is: <mqtt_prefix>/_CLIENTS/ZWAVE_GATEWAY-<mqtt_name>/api/<api_name>/setJSON args
where:
<mqtt_name> is from your GUI->Settings->mqtt->Name.
<mqtt_prefix> is from your GUI->Settings->mqtt->Prefix. In your case its openzwave
<api_name> - If you actually want to use the requestnodedynamic, then the OZW API is RequestNodeDynamic (uint32 const _homeId, uint8 const _nodeId)
and the <api_name> has to have the first letter downcased so it will be requestNodeDynamic.
JSON args is the MQTT message/value for this topic and will contain the JSON string { “args”: “0xYYYYYYYY”, “N” ] } where 0xYYYYYYYY is replaced by your home-id found at the top of your GUI, and “N” is the integer of your node-id.
As an example, if you use mosquito, you could publish it using something like:
