So I am playing around with the new zwave2mqtt integration. I successfully added my Kwikset doorlock with control working in Home Assistant. But for the life of me I just can’t figure out why I can’t get my WADWAZ-1 from Nortek to work correctly.
From what I can tell, the device will add successfully and will report it’s initial state to Home Assistant but that’s it. It will stay in the sleeping state forever even when I close and open the door. From what I can tell, there is no MQTT message fired when the door opens and closes, So I think it’s a ZWAVE problem?
In the debug console I can see this following:
OpenZWave Detail, Node013, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0d, 0x03, 0x20, 0x01, 0x00, 0xdd
OpenZWave Detail,
OpenZWave Info, Node013, Received Basic set from node 13: level=0. Treating it as a Basic report.
OpenZWave Detail, Node013, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0d, 0x0a, 0x71, 0x05, 0x07, 0x00, 0x00, 0xff, 0x07, 0x02, 0x00, 0x00, 0x65
OpenZWave Detail,
OpenZWave Warning, NotificationCCTypes::GetAlarmNotificationTypes - Unknown Alarm Type 7
OpenZWave Warning, NotificationCCTypes::GetEventForAlarmType - Unknown AlarmType/Event 7/d
OpenZWave Warning, NotificationCCTypes::GetAlarmType - Unknown AlarmType 7
OpenZWave Info, Node013, Received Notification report (>v1): Type: Unknown (7) Event: Unknown (2) Status: true, Param Length: 0
OpenZWave Warning, Node013, Couldn't Find a ValueList for Notification Type 7 (1)
OpenZWave Info, Node013, Automatically Clearing Alarm in 5000ms
OpenZWave Info, Timer: adding event in 5000 ms
OpenZWave Detail, Timer: waiting with timeout 5000 ms
And here is what’s under Hass Device JSON:
"type": "binary_sensor",
"object_id": "contact",
"discovery_payload": {
"payload_on": true,
"payload_off": false,
"value_template": "{{ value_json.value }}",
"device_class": "door",
"state_topic": "homeassistant/nodeID_13/48/1/0",
"json_attributes_topic": "homeassistant/nodeID_13/48/1/0",
"device": {
"identifiers": [
"zwave2mqtt_0xdebbaeb6_node13"
"manufacturer": "Linear (Nortek Security Control LLC)",
"model": "WADWAZ-1 Door/Window Sensor (0x0102)",
"name": "nodeID_13",
"sw_version": "4.84"
"name": "nodeID_13_contact",
"unique_id": "zwave2mqtt_0xdebbaeb6_13-48-1-0"
"discoveryTopic": "binary_sensor/nodeID_13/contact/config",
"values": [
"48-1-0"
"persistent": false,
"id": "binary_sensor_contact"
Please Help, I don’t know where to start.
